Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
0
Syntax error. HDLCompiler:806
hey there!
I am very new to FPGA's so bear with any silly mistakes but I made this VHDL file for the NEXSYS2, spartan 3e FPGA with this UCF file:
VHDL File:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
-- Vergelijkers 8 bit --
-- LET OP COMP8 is nu nog een COMP4 omdat er maar 8 schakelaars op het bord zijn.
entity Comp8 is
port(CA8, CB8 : in std_logic_vector(3 downto 0);
IsEqualCP8 : out std_logic;
IsGrterCP8 : out std_logic;
IsSmllrCP8 : out std_logic;
SwapBtn : in std_logic);
end Comp8;
architecture AComp8 of Comp8 is
begin
if(SwapBtn = '0') then
IsEqualCP8 <= '1' when (CA8=CB8) else '0';
IsGrterCP8 <= '1' when (CA8>CB8) else '0';
IsSmllrCP8 <= '1' when (CA8<CB8) else '0';
elsif(SwapBtn = '1') then
IsGrterCP8 <= '1' when (CB8>CA8) else '0';
IsSmllrCP8 <= '1' when (CB8<CA8) else '0';
end if;
end AComp8;
and this UCF file:
NET "IsEqualCP8" LOC="J14"; --this is a led
NET "IsGrterCP8" LOC="J15";
--this is a led
NET "IsSmllrCP8" LOC="K15"; --this is a led
NET "CA8<0>" LOC="G18"; -- this is a switch
NET "CA8<1>" LOC="H18";
-- this is a switch
NET "CA8<2>" LOC="K18"; -- this is a switch
NET "CA8<3>" LOC="K17"; -- this is a switch
NET "CB8<0>" LOC="L14"; -- this is a switch
NET "CB8<1>" LOC="L13"; -- this is a switch
NET "CB8<2>" LOC="N17"; -- this is a switch
NET "CB8<3>" LOC="R17"; -- this is a switch
NET "SwapBtn" LOC="H13"; --this is a push button
Now the problem is that on syntax checking It throws these errors (three of them) : HDLCompiler:806. The errors refer to the blue marked lines in the VDHL file above.
"D:/Matthias Map/EINDWERKSTUK/FPGA/Projecten/testprojecten/Test0/Test0.vhd" Line 22: Syntax error near "if".
"D:/Matthias Map/EINDWERKSTUK/FPGA/Projecten/testprojecten/Test0/Test0.vhd" Line 26: Syntax error near "elsif".
"D:/Matthias Map/EINDWERKSTUK/FPGA/Projecten/testprojecten/Test0/Test0.vhd" Line 29: Syntax error near "if".
can anyone help me with this? The intend of the file is that you can compare two 4 bit numbers to be equal, greater then or smaller then one another. When NOT holding the push button it compares:
A=B
A<B
A>B
when holding the push button it should compare:
B=A -- I did not include that to avoid duplicate code
B<A
B>A
Could anybody help me out? many thanks in advance!
Expert Contributor
0
Re: Syntax error. HDLCompiler:806
Your "if" statements need to be inside a process.
-- Gabor
0
Thanks. But how would I make this a process? Could you show me how I must code this in order for it  to work?
Expert Contributor
0
Well I was hoping you would open your VHDL reference book, but...
Try:
begin
MY_PROCESS : process (CA8, CB8, SwapBtn) is
begin
  end if;
end process MY_PROCESS;
end AComp8;
-- Gabor
0
I would open up a textbook if I had any :P
It didn't work btw, gave errors near "when'
I'll work on it tommorow.
Expert Contributor
0
Yeah, that's true.  That syntax is only useful for an assignment outside a process.  I
have to say that VHDL is not my strong suit, but I dabble in it whenever I need to use
someone else's code.  There may be a more elegant way to write this, but you might
want to change your "when" syntax to "if" syntax like:
    if CA8 = CB8 then IsEqualCP8 <= '1';
    else IsEqualCP8 <= '0';
    end if;
Otherwise you could try to dump the process idea and merge your original "if"
statements into the "when" assignments like:
IsGrterCP8 <= '1' when (SwapBtn = '0') and (CA8>CB8) or (SwapBtn = '1') and (CB8>CA8) else '0';
But that isn't very readable.
By the way you don't have an assignment for IsEqualCP8 when SwapBtn = '1'
This will create a latch.
Finally I don't particularly like the syntax
if (SwapBtn = '0') then
elsif (SwapBtn = '1') then
end if;
When you really mean:
else
end if;
The latter makes it more clear that you have covered all cases and won't generate a latch.
Gabor
-- Gabor
Expert Contributor
0
So, stop right now, hit your favorite online or real-world book store, and buy a copy of Peter Ashenden's "The Designer's Guide To VHDL."
As in, like right now.
Yes, I do this for a living.
0
I'm having a similar problem with a Verilog testbench. I have this file below that gives me a syntax error near "end." But I have another file from the homework I'm doing that compiles fine and is literally the same code.
`timescale 1ns / 1ps
module ee101_hw5_q4_tb();
// Inputs
   reg [4:0] X;
// Output
   wire [5:0] Y;
// Bidirs
// Instantiate the UUT
   ee101_hw5_q4 UUT (
        .X(X),
        .Y(Y)
// Initialize Inputs
        integer i;
       initial begin
            for (i = 0; i < 32; i = i + 1)
            begin
                X = i;
                #100;
            end
        end
endmodule
0
I know it's very simple, but please help!
0
Sorry,
but I have 4 home works and 2 projects if any one can help me.
