取消
显示结果
搜索替代
您的意思是:
317 次查看
注册日期: ‎04-05-2018
petalinux-build --sdk失败,petalinux2018.3
转到解答
使用petalinux2018.3运行命令
失败,错误如下:
ERROR: nativesdk-qemu-xilinx-v2.11.0-xilinx-v2018.3+gitAUTOINC+f70bd86859-r0 do_compile: oe_runmake failed
ERROR: nativesdk-qemu-xilinx-v2.11.0-xilinx-v2018.3+gitAUTOINC+f70bd86859-r0 do_compile: Function failed: do_compile (log file is located at /opt/petalinux_prj/sdirx_vcu4/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.3+gitAUTOINC+f70bd86859-r0/temp/log.do_compile.10602)
ERROR: Logfile of failure stored in: /opt/petalinux_prj/sdirx_vcu4/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.3+gitAUTOINC+f70bd86859-r0/temp/log.do_compile.10602
Log data follows:
| DEBUG: SITE files ['endian-little', 'common-linux', 'common-glibc', 'bit-64', 'x86_64-linux', 'common']
| DEBUG: Executing shell function do_compile
| NOTE: make -j 6
|   GEN     aarch64-linux-user/config-devices.mak.tmp
|   GEN     aarch64-softmmu/config-devices.mak.tmp
|   GEN     arm-linux-user/config-devices.mak.tmp
|   GEN     arm-softmmu/config-devices.mak.tmp
|   GEN     microblaze-linux-user/config-devices.mak.tmp
|   GEN     microblaze-softmmu/config-devices.mak.tmp
|   GEN     microblazeel-linux-user/config-devices.mak.tmp
|   GEN     microblazeel-softmmu/config-devices.mak.tmp
|   GEN     config-host.h
|   GIT     ui/keycodemapdb capstone
|   GEN     qemu-options.def
|   GEN     qmp-commands.h
|   GEN     qapi-types.h
|   GEN     qapi-visit.h
|   GEN     qapi-event.h
|   GEN     qmp-marshal.c
|   GEN     qapi-types.c
|   GEN     qapi-visit.c
|   GEN     qapi-event.c
|   GEN     qmp-introspect.h
|   GEN     qmp-introspect.c
|   GEN     trace/generated-tcg-tracers.h
|   GEN     trace/generated-helpers-wrappers.h
|   GEN     trace/generated-helpers.h
|   GEN     trace/generated-helpers.c
|   GEN     module_block.h
|   GEN     tests/test-qapi-types.h
|   GEN     tests/test-qapi-visit.h
|   GEN     tests/test-qmp-commands.h
|   GEN     tests/test-qapi-event.h
|   GEN     tests/test-qmp-introspect.h
|   GEN     trace-root.h
|   GEN     util/trace.h
|   GEN     crypto/trace.h
|   GEN     io/trace.h
|   GEN     migration/trace.h
|   GEN     block/trace.h
|   GEN     chardev/trace.h
|   GEN     hw/block/trace.h
|   GEN     hw/block/dataplane/trace.h
|   GEN     hw/char/trace.h
|   GEN     hw/intc/trace.h
|   GEN     hw/net/trace.h
|   GEN     hw/virtio/trace.h
|   GEN     hw/audio/trace.h
|   GEN     hw/misc/trace.h
|   GEN     hw/usb/trace.h
|   GEN     hw/scsi/trace.h
|   GEN     hw/nvram/trace.h
|   GEN     hw/display/trace.h
|   GEN     hw/input/trace.h
|   GEN     hw/timer/trace.h
|   GEN     hw/dma/trace.h
|   GEN     hw/sparc/trace.h
|   GEN     hw/sd/trace.h
|   GEN     hw/isa/trace.h
|   GEN     hw/mem/trace.h
|   GEN     hw/i386/trace.h
|   GEN     hw/i386/xen/trace.h
|   GEN     hw/9pfs/trace.h
|   GEN     hw/ppc/trace.h
|   GEN     hw/pci/trace.h
|   GEN     hw/s390x/trace.h
|   GEN     hw/vfio/trace.h
|   GEN     hw/acpi/trace.h
|   GEN     hw/arm/trace.h
|   GEN     hw/alpha/trace.h
|   GEN     hw/xen/trace.h
|   GEN     hw/ide/trace.h
| Submodule 'capstone' (git://git.qemu.org/capstone.git) registered for path 'capstone'
| Submodule 'ui/keycodemapdb' (git://git.qemu.org/keycodemapdb.git) registered for path 'ui/keycodemapdb'
|   GEN     ui/trace.h
|   GEN     audio/trace.h
|   GEN     net/trace.h
|   GEN     target/arm/trace.h
|   GEN     target/i386/trace.h
|   GEN     target/mips/trace.h
| Cloning into '/opt/petalinux_prj/sdirx_vcu4/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.3+gitAUTOINC+f70bd86859-r0/git/capstone'...
|   GEN     target/sparc/trace.h
|   GEN     target/s390x/trace.h
|   GEN     target/ppc/trace.h
|   GEN     qom/trace.h
|   GEN     linux-user/trace.h
|   GEN     qapi/trace.h
|   GEN     accel/tcg/trace.h
|   GEN     accel/kvm/trace.h
| fatal: unable to access 'http://git.qemu.or/git/capstone.git/': Could not resolve host: git.qemu.or
| fatal: clone of 'git://git.qemu.org/capstone.git' into submodule path '/opt/petalinux_prj/sdirx_vcu4/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.3+gitAUTOINC+f70bd86859-r0/git/capstone' failed
| Failed to clone 'capstone'. Retry scheduled
|   GEN     nbd/trace.h
|   GEN     scsi/trace.h
|   GEN     trace-root.c
| Cloning into '/opt/petalinux_prj/sdirx_vcu4/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.3+gitAUTOINC+f70bd86859-r0/git/ui/keycodemapdb'...
|   GEN     util/trace.c
|   GEN     crypto/trace.c
|   GEN     io/trace.c
|   GEN     migration/trace.c
|   GEN     block/trace.c
|   GEN     chardev/trace.c
|   GEN     hw/block/trace.c
|   GEN     hw/block/dataplane/trace.c
|   GEN     hw/char/trace.c
|   GEN     hw/intc/trace.c
|   GEN     hw/net/trace.c
|   GEN     hw/virtio/trace.c
|   GEN     hw/audio/trace.c
|   GEN     hw/misc/trace.c
|   GEN     hw/usb/trace.c
|   GEN     hw/scsi/trace.c
|   GEN     hw/nvram/trace.c
|   GEN     hw/display/trace.c
|   GEN     hw/input/trace.c
|   GEN     hw/timer/trace.c
|   GEN     hw/dma/trace.c
|   GEN     hw/sparc/trace.c
|   GEN     hw/sd/trace.c
|   GEN     hw/isa/trace.c
|   GEN     hw/mem/trace.c
|   GEN     hw/i386/trace.c
|   GEN     hw/i386/xen/trace.c
|   GEN     hw/9pfs/trace.c
|   GEN     hw/ppc/trace.c
|   GEN     hw/pci/trace.c
|   GEN     hw/s390x/trace.c
|   GEN     hw/vfio/trace.c
|   GEN     hw/acpi/trace.c
|   GEN     hw/arm/trace.c
|   GEN     hw/alpha/trace.c
|   GEN     hw/xen/trace.c
|   GEN     hw/ide/trace.c
|   GEN     ui/trace.c
|   GEN     audio/trace.c
|   GEN     net/trace.c
|   GEN     target/arm/trace.c
|   GEN     target/i386/trace.c
|   GEN     target/mips/trace.c
|   GEN     target/sparc/trace.c
|   GEN     target/s390x/trace.c
|   GEN     target/ppc/trace.c
|   GEN     qom/trace.c
|   GEN     linux-user/trace.c
|   GEN     qapi/trace.c
|   GEN     accel/tcg/trace.c
|   GEN     accel/kvm/trace.c
|   GEN     nbd/trace.c
|   GEN     scsi/trace.c
|   GEN     config-all-devices.mak
| fatal: unable to access 'http://git.qemu.or/git/keycodemapdb.git/': Failed to connect to git.qemu.or port 80: Connection timed out
| fatal: clone of 'git://git.qemu.org/keycodemapdb.git' into submodule path '/opt/petalinux_prj/sdirx_vcu4/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.3+gitAUTOINC+f70bd86859-r0/git/ui/keycodemapdb' failed
| Failed to clone 'ui/keycodemapdb'. Retry scheduled
| fatal: unable to access 'http://git.qemu.or/git/capstone.git/': Failed to connect to git.qemu.or port 80: Connection timed out
| ERROR: oe_runmake failed
| Failed to clone 'capstone' a second time, aborting
| ./scripts/git-submodule.sh: failed to update modules
| Unable to automatically checkout GIT submodules ' ui/keycodemapdb capstone'.
| If you require use of an alternative GIT binary (for example to
| enable use of a transparent proxy), then please specify it by
| running configure by with the '--with-git' argument. e.g.
|  $ ./configure --with-git='tsocks git'
| Alternatively you may disable automatic GIT submodule checkout
| with:
|  $ ./configure --disable-git-update'
| and then manually update submodules prior to running make, with:
|  $ scripts/git-sbumodule.sh update  ui/keycodemapdb capstone
| make: *** [Makefile:39: git-submodule-update] Error 1
| WARNING: /opt/petalinux_prj/sdirx_vcu4/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.3+gitAUTOINC+f70bd86859-r0/temp/run.do_compile.10602:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /opt/petalinux_prj/sdirx_vcu4/build/tmp/work/x86_64-nativesdk-petalinux-linux/nativesdk-qemu-xilinx/v2.11.0-xilinx-v2018.3+gitAUTOINC+f70bd86859-r0/temp/log.do_compile.10602)
ERROR: Task (virtual:nativesdk:/media/scw/ubuntu16.04/ubuntu/software/petalinux1803/components/yocto/source/aarch64/layers/meta-xilinx/meta-xilinx-bsp/recipes-devtools/qemu/qemu-xilinx_2018.3.bb:do_compile) failed with exit code '1'
log在附件。
请问大家知道怎么解决吗?
0 项奖励
1 个已接受解答
已接受的解答
274 次查看
注册日期: ‎04-15-2011
回复: petalinux-build --sdk失败,petalinux2018.3
转到解答
@hgtcs
你的编译环境有连接网络吗?build sdk的时候,需要更多的库及其源代码,而通常这些库及源码并不包含在ssate cache里,所以需要连接网络下载。
0 项奖励
2 条回复2
275 次查看
注册日期: ‎04-15-2011
转到解答
@hgtcs
0 项奖励
77 次查看
注册日期: ‎03-16-2013
转到解答
请问, petalinux-build --sdk这个步骤是必须的吗,我再petalinux2017.4里没看到这个步骤
0 项奖励
