取消
显示结果
搜索替代
您的意思是:
350 次查看
注册日期: ‎11-23-2018
petalinux sd卡启动,Waiting for root device /dev/mmcblk0p2
环境:vivado2018.2,petalinux2018.2,ubuntu16.04
hw配置:sd1,uart0,iic0,ddr4
sd分区:
用DiskGenius x64分为两个分区:一个BOOT(fat32),一个rootfs(EXT4)
制作sd卡启动:
petalinuc-create、petalinux-config(弹出配置窗口,不做修改,采用默认)、petalinux-build、petalinux-package
导入BOOT image.ub到BOOT分区,解压rootfs.tar.gz到rootfs分区,将板子启动方式调整为sd卡启动,连接串口,上电启动之后,显示能够登陆root,
但是打印的信息中有如下错误,并且启动的系统好像不是rootfs中的系统,而是image.ub中的,
mmc0: error -110 whilst initialising SD card
查阅ug1144,发现在petalinux-config步骤中的配置选项需要修改为SD card,按照配置要求,重新制作BOOT、image.ub、rootfs.tar.gz
上电启动,系统无法正常进入root登陆界面,卡死,有两个问题:
一是仍然有错误:
[    1.656331] mmc0: error -110 whilst initialising SD card
二是卡在:
[    2.973502] Waiting for root device /dev/mmcblk0p2...
此情况完整串口打印如下:
Device: sdhci@ff170000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.7 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
6967476 bytes read in 465 ms (14.3 MiB/s)
   Using 'conf@system-top.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x10000104
     Data Size:    6935331 Bytes = 6.6 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   b1594d5bef3ad3196a4abd18624a72dbb3a3a158
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x1069d52c
     Data Size:    30225 Bytes = 29.5 KiB
     Hash algo:    sha1
     Hash value:   c48615e6c9c8e73dcfc77cfef1fd8673de2b891c
   Booting using the fdt blob at 0x1069d52c
   Uncompressing Kernel Image ... OK
   Loading Device Tree to 0000000007ff5000, end 0000000007fff610 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.0-xilinx-v2018.2 (oe-user@oe-host) (gcc version 7.2.0 (GCC)) #1 SMP Tue Jan 22 18:44:03 CST 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Machine model: xlnx,zynqmp
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x000000006fc00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] percpu: Embedded 21 pages/cpu @ffffffc07fe7a000 s46488 r8192 d31336 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516867
[    0.000000] Kernel command line: earlycon clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 1785244K/2096128K available (9916K kernel code, 644K rwdata, 3124K rodata, 512K init, 2168K bss, 48740K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008a30000   (  9920 KB)
[    0.000000]     .rodata : 0xffffff8008a30000 - 0xffffff8008d40000   (  3136 KB)
[    0.000000]       .init : 0xffffff8008d40000 - 0xffffff8008dc0000   (   512 KB)
[    0.000000]       .data : 0xffffff8008dc0000 - 0xffffff8008e61200   (   645 KB)
[    0.000000]        .bss : 0xffffff8008e61200 - 0xffffff800907f2b0   (  2169 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf01bfc800   (    27 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc07ff00000   (  2047 MB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU event tracing is enabled.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 33.33MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x7b0074340, max_idle_ns: 440795202884 ns
[    0.000003] sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 2199023255543ns
[    0.008239] Console: colour dummy device 80x25
[    0.012498] console [tty0] enabled
[    0.015864] bootconsole [cdns0] disabled
[    0.019773] Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133332)
[    0.019787] pid_max: default: 32768 minimum: 301
[    0.019890] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.019905] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.020500] ASID allocator initialised with 65536 entries
[    0.020549] Hierarchical SRCU implementation.
[    0.020825] EFI services will not be available.
[    0.020850] zynqmp_plat_init Platform Management API v1.0
[    0.020858] zynqmp_plat_init Trustzone version v1.0
[    0.020956] smp: Bringing up secondary CPUs ...
[    0.021209] Detected VIPT I-cache on CPU1
[    0.021240] CPU1: Booted secondary processor [410fd034]
[    0.021516] Detected VIPT I-cache on CPU2
[    0.021535] CPU2: Booted secondary processor [410fd034]
[    0.021796] Detected VIPT I-cache on CPU3
[    0.021814] CPU3: Booted secondary processor [410fd034]
[    0.021854] smp: Brought up 1 node, 4 CPUs
[    0.021887] SMP: Total of 4 processors activated.
[    0.021895] CPU features: detected feature: 32-bit EL0 Support
[    0.021906] CPU: All CPU(s) started at EL2
[    0.021922] alternatives: patching kernel code
[    0.022640] devtmpfs: initialized
[    0.025691] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[    0.025893] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.025915] futex hash table entries: 1024 (order: 5, 131072 bytes)
[    0.026060] random: fast init done
[    0.030862] xor: measuring software checksum speed
[    0.067855]    8regs     :  2303.000 MB/sec
[    0.107884]    8regs_prefetch:  2053.000 MB/sec
[    0.147916]    32regs    :  2830.000 MB/sec
[    0.187942]    32regs_prefetch:  2381.000 MB/sec
[    0.187950] xor: using function: 32regs (2830.000 MB/sec)
[    0.188023] pinctrl core: initialized pinctrl subsystem
[    0.188591] NET: Registered protocol family 16
[    0.189411] cpuidle: using governor menu
[    0.189767] vdso: 2 pages (1 code @ ffffff8008a36000, 1 data @ ffffff8008dc4000)
[    0.189784] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.190325] DMA: preallocated 256 KiB pool for atomic allocations
[    0.219882] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[    0.220355] ARM CCI_400_r1 PMU driver probed
[    0.224590] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[    0.231618] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.296220] raid6: int64x1  gen()   403 MB/s
[    0.364149] raid6: int64x1  xor()   446 MB/s
[    0.432219] raid6: int64x2  gen()   688 MB/s
[    0.500216] raid6: int64x2  xor()   603 MB/s
[    0.568261] raid6: int64x4  gen()  1042 MB/s
[    0.636329] raid6: int64x4  xor()   742 MB/s
[    0.704388] raid6: int64x8  gen()   980 MB/s
[    0.772383] raid6: int64x8  xor()   745 MB/s
[    0.840485] raid6: neonx1   gen()   727 MB/s
[    0.908500] raid6: neonx1   xor()   853 MB/s
[    0.976571] raid6: neonx2   gen()  1169 MB/s
[    1.044589] raid6: neonx2   xor()  1208 MB/s
[    1.112656] raid6: neonx4   gen()  1505 MB/s
[    1.180671] raid6: neonx4   xor()  1442 MB/s
[    1.248727] raid6: neonx8   gen()  1651 MB/s
[    1.316778] raid6: neonx8   xor()  1533 MB/s
[    1.316786] raid6: using algorithm neonx8 gen() 1651 MB/s
[    1.316794] raid6: .... xor() 1533 MB/s, rmw enabled
[    1.316802] raid6: using neon recovery algorithm
[    1.317582] SCSI subsystem initialized
[    1.317738] usbcore: registered new interface driver usbfs
[    1.317774] usbcore: registered new interface driver hub
[    1.317808] usbcore: registered new device driver usb
[    1.317876] media: Linux media interface: v0.10
[    1.317906] Linux video capture interface: v2.00
[    1.317950] pps_core: LinuxPPS API ver. 1 registered
[    1.317959] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.317983] PTP clock support registered
[    1.318014] EDAC MC: Ver: 3.0.0
[    1.318588] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[    1.318745] FPGA manager framework
[    1.318855] fpga-region fpga-full: FPGA Region probed
[    1.318942] Advanced Linux Sound Architecture Driver Initialized.
[    1.319205] Bluetooth: Core ver 2.22
[    1.319231] NET: Registered protocol family 31
[    1.319239] Bluetooth: HCI device and connection manager initialized
[    1.319251] Bluetooth: HCI socket layer initialized
[    1.319263] Bluetooth: L2CAP socket layer initialized
[    1.319281] Bluetooth: SCO socket layer initialized
[    1.319877] clocksource: Switched to clocksource arch_sys_counter
[    1.319954] VFS: Disk quotas dquot_6.6.0
[    1.319998] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.323967] NET: Registered protocol family 2
[    1.324266] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.324379] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.324587] TCP: Hash tables configured (established 16384 bind 16384)
[    1.324663] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.324707] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.324825] NET: Registered protocol family 1
[    1.325031] RPC: Registered named UNIX socket transport module.
[    1.325041] RPC: Registered udp transport module.
[    1.325048] RPC: Registered tcp transport module.
[    1.325055] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.325471] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.325620] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.326229] audit: initializing netlink subsys (disabled)
[    1.326592] audit: type=2000 audit(1.308:1): state=initialized audit_enabled=0 res=1
[    1.326630] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    1.327283] NFS: Registering the id_resolver key type
[    1.327304] Key type id_resolver registered
[    1.327312] Key type id_legacy registered
[    1.327325] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.327346] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.350995] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.351016] io scheduler noop registered
[    1.351024] io scheduler deadline registered
[    1.351044] io scheduler cfq registered (default)
[    1.351053] io scheduler mq-deadline registered
[    1.351061] io scheduler kyber registered
[    1.352140] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    1.352294] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    1.352432] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    1.352573] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    1.352711] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    1.352852] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    1.352996] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    1.353136] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    1.353344] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    1.353487] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    1.353628] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    1.353766] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    1.353908] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    1.354046] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    1.354191] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    1.354330] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    1.379483] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.382008] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.386189] brd: module loaded
[    1.389712] loop: module loaded
[    1.390354] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.391400] libphy: Fixed MDIO Bus: probed
[    1.392418] tun: Universal TUN/TAP device driver, 1.6
[    1.392552] CAN device driver interface
[    1.393188] usbcore: registered new interface driver asix
[    1.393240] usbcore: registered new interface driver ax88179_178a
[    1.393272] usbcore: registered new interface driver cdc_ether
[    1.393302] usbcore: registered new interface driver net1080
[    1.393332] usbcore: registered new interface driver cdc_subset
[    1.393364] usbcore: registered new interface driver zaurus
[    1.393405] usbcore: registered new interface driver cdc_ncm
[    1.393695] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    1.394073] usbcore: registered new interface driver uas
[    1.394114] usbcore: registered new interface driver usb-storage
[    1.394621] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    1.394669] i2c /dev entries driver
[    1.395025] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 31
[    1.395208] IR NEC protocol handler initialized
[    1.395217] IR RC5(x/sz) protocol handler initialized
[    1.395225] IR RC6 protocol handler initialized
[    1.395232] IR JVC protocol handler initialized
[    1.395239] IR Sony protocol handler initialized
[    1.395246] IR SANYO protocol handler initialized
[    1.395253] IR Sharp protocol handler initialized
[    1.395260] IR MCE Keyboard/mouse protocol handler initialized
[    1.395268] IR XMP protocol handler initialized
[    1.396131] usbcore: registered new interface driver uvcvideo
[    1.396140] USB Video Class driver (1.1.1)
[    1.396518] Bluetooth: HCI UART driver ver 2.3
[    1.396528] Bluetooth: HCI UART protocol H4 registered
[    1.396537] Bluetooth: HCI UART protocol BCSP registered
[    1.396563] Bluetooth: HCI UART protocol LL registered
[    1.396572] Bluetooth: HCI UART protocol ATH3K registered
[    1.396581] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.396620] Bluetooth: HCI UART protocol Intel registered
[    1.396628] Bluetooth: HCI UART protocol QCA registered
[    1.396662] usbcore: registered new interface driver bcm203x
[    1.396697] usbcore: registered new interface driver bpa10x
[    1.396731] usbcore: registered new interface driver bfusb
[    1.396764] usbcore: registered new interface driver btusb
[    1.396773] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    1.396825] usbcore: registered new interface driver ath3k
[    1.396948] EDAC MC: ECC not enabled
[    1.397108] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    1.397911] sdhci: Secure Digital Host Controller Interface driver
[    1.397921] sdhci: Copyright(c) Pierre Ossman
[    1.397928] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.443884] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[    1.443958] PLL: shutdown
[    1.444050] PLL: enable
[    1.450050] ledtrig-cpu: registered to indicate activity on CPUs
[    1.450197] usbcore: registered new interface driver usbhid
[    1.450206] usbhid: USB HID core driver
[    1.451988] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    1.453700] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    1.456121] Netfilter messages via NETLINK v0.30.
[    1.456243] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.456374] Initializing XFRM netlink socket
[    1.456444] NET: Registered protocol family 10
[    1.456804] Segment Routing with IPv6
[    1.456849] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.456969] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.457291] NET: Registered protocol family 17
[    1.457307] NET: Registered protocol family 15
[    1.457328] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.457342] Ebtables v2.0 registered
[    1.457429] can: controller area network core (rev 20170425 abi 9)
[    1.457465] NET: Registered protocol family 29
[    1.457474] can: raw protocol (rev 20170425)
[    1.457482] can: broadcast manager protocol (rev 20170425 t)
[    1.457494] can: netlink gateway (rev 20170425) max_hops=1
[    1.457550] Bluetooth: RFCOMM TTY layer initialized
[    1.457562] Bluetooth: RFCOMM socket layer initialized
[    1.457576] Bluetooth: RFCOMM ver 1.11
[    1.457587] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.457595] Bluetooth: BNEP filters: protocol multicast
[    1.457605] Bluetooth: BNEP socket layer initialized
[    1.457613] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.457623] Bluetooth: HIDP socket layer initialized
[    1.457722] 9pnet: Installing 9P2000 support
[    1.457741] Key type dns_resolver registered
[    1.458129] registered taskstats version 1
[    1.458453] Btrfs loaded, crc32c=crc32c-generic
[    1.463651] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 37, base_baud = 6249999) is a xuartps
[    2.948491] console [ttyPS0] enabled
[    2.953728] rtc_zynqmp ffa60000.rtc: setting system clock to 2103-06-05 10:35:10 UTC (4210482910)
[    2.962630] clk: Not disabling unused clocks
[    2.966848] ALSA device list:
[    2.969766]   No soundcards found.
0 项奖励
1 条回复1
347 次查看
注册日期: ‎04-15-2011
回复: petalinux sd卡启动,Waiting for root device /dev/mmcblk0p2
从你的描述看来,你的SD卡在Linux下面初始化有问题。你能发一下编译后的SD的dts node吗?
你可以按照下面的AR限制MMC的频率试试。
https://www.xilinx.com/support/answers/69995.html
0 项奖励
