取消
显示结果
搜索替代
您的意思是:
1,257 次查看
注册日期: ‎02-16-2012
加速PetaLinux工程编译过程
加速PetaLinux工程编译过程
1: 使用local sstate。请参见下列readme.
2: 使用本地download目录,重新使用已经下载好的文件。请参见下列readme.
3: 关闭网络接口,如使用命令 ifconfig eth0 down.
By default petalinux uses sstate-cache and download mirrors from petalinux.xilinx.com
This README is for the users who uses tool completely offline.
Setting sstate cache
1) Extract the downloaded tar contents of sstate-cache at any location
2) run petalinux-config
-> Yocto Settings
->Local sstate feeds settings
->local sstate feeds url
(press Enter)
3) Provide the path of sstate-cache from above
Ex: /<path>/aarch64 for ZynqMP projects
/<path>/arm for Zynq projects
/<path>/mb-full for MB AXI full projects
4) Save the configurations to use the sstate-cache
Setting download mirror
-> Yocto Settings
-> Add pre-mirror url
-> (press Enter)
Clear default value
file://<path>/downloads for all projects
4) Save the configurations to use the download mirrors
5) Verify the changes in build/conf/plnxtool.conf
6) petalinux-build
标记 (3)
0 项奖励
2 条回复2
1,116 次查看
注册日期: ‎02-16-2012
回复: 加速PetaLinux工程编译过程
第一步: 下载Sstate,设置local Sstate,
第二步: 设置镜像URL;
第三步: 编译;
第四步: 成功的编译之后,Ifconfig禁止所有网卡;
0 项奖励
Observer redglass
1,058 次查看
注册日期: ‎06-11-2018
Hi 按照上面的操作,配置了禁止 'enable Network sstate feeds', 使能 'enable BB no network',后编译不通过,提示:
ERROR: linux-xlnx-4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0 do_fetch: The URL: '/home/shawn/Xilinx/sstate-rel-v2018.2/downloads' is invalid and cannot be interpreted
ERROR: linux-xlnx-4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/shawn/Peta201802/xilinx-zcu104-2018.2/build/tmp/work/zcu104_zynqmp-xilinx-linux/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/temp/log.do_fetch.27238
ERROR: Task (/home/shawn/Peta201802/components/yocto/source/aarch64/layers/meta-xilinx/meta-xilinx-bsp/recipes-kernel/linux/linux-xlnx_2018.2.bb:do_fetch) failed with exit code '1'
ERROR: libmali-xlnx-r8p0-01rel0-r0 do_fetch: The URL: '/home/shawn/Xilinx/sstate-rel-v2018.2/downloads' is invalid and cannot be interpreted
ERROR: libmali-xlnx-r8p0-01rel0-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/shawn/Peta201802/xilinx-zcu104-2018.2/build/tmp/work/zynqmp-xilinx-linux/libmali-xlnx/r8p0-01rel0-r0/temp/log.do_fetch.27248
ERROR: Task (/home/shawn/Peta201802/components/yocto/source/aarch64/layers/meta-xilinx/meta-xilinx-bsp/recipes-graphics/libgles/libmali-xlnx_git.bb:do_fetch) failed with exit code '1'
0 项奖励
