取消
显示结果
搜索替代
您的意思是:
Observer fangzhengshu
804 次查看
注册日期: ‎08-27-2018
官方BSP 使用QEMU验证启动异常
转到解答
1、安装petalinux:
./petalinux-v2018.1-final-installer.run petalinux-v2018.1
2、使用官方BSP创建工程:
petalinux-create -t project -s xilinx-zcu106-v2018.1-final.bsp
3、使用qemu启动:
cd xilinx-zcu106-2018.1
petalinux-boot --qemu --prebuilt 3
错误信息如下:
fangzheng@HP:~/workspace/app/xilinx-zcu106-2018.1$ petalinux-boot --qemu --prebuilt 3
INFO: Set QEMU tftp to /home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/
INFO: TCP PORT is free
INFO: Starting aarch64 QEMU
INFO:  qemu-system-aarch64 -M arm-generic-fdt   -display none -device loader,file=/home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/pmu_rom_qemu_sha3.elf,cpu-num=0 -gdb tcp::9000 -dtb /tmp/tmp.wNQ4gBmnIv     -hw-dtb /mnt/workspace/app/xilinx-zcu106-2018.1/images/linux/zynqmp-qemu-multiarch-arm.dtb -machine-path /tmp/tmp.vjItVq63wU -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true  -m 4G
qemu-system-aarch64: Unable to get size of device tree file '/tmp/tmp.wNQ4gBmnIv'
qemu-system-aarch64: Error: Unable to load Device Tree /tmp/tmp.wNQ4gBmnIv
INFO:  qemu-system-aarch64 -M arm-generic-fdt   -display none -device loader,file=/home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/pmufw.elf,cpu-num=0 -gdb tcp::9000 -dtb /tmp/tmp.8d1VYumwaS     -hw-dtb /mnt/workspace/app/xilinx-zcu106-2018.1/images/linux/zynqmp-qemu-multiarch-arm.dtb -machine-path /tmp/tmp.vjItVq63wU -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true  -m 4G
qemu-system-aarch64: Unable to get size of device tree file '/tmp/tmp.8d1VYumwaS'
qemu-system-aarch64: Error: Unable to load Device Tree /tmp/tmp.8d1VYumwaS
INFO:  qemu-system-aarch64 -M arm-generic-fdt   -display none -device loader,file=/home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/bl31.elf,cpu-num=0 -device loader,file=/home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/Image,addr=0x00080000 -device loader,file=/home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/system.dtb,addr=0x1407f000 -device loader,file=/home/fangzheng/workspace/app/xilinx-zcu106-2018.1/build/misc/linux-boot/linux-boot.elf -gdb tcp::9000 -dtb /tmp/tmp.gcPUdBLEyq     -hw-dtb /mnt/workspace/app/xilinx-zcu106-2018.1/images/linux/zynqmp-qemu-multiarch-arm.dtb -machine-path /tmp/tmp.vjItVq63wU -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true  -m 4G
qemu-system-aarch64: Unable to get size of device tree file '/tmp/tmp.gcPUdBLEyq'
qemu-system-aarch64: Error: Unable to load Device Tree /tmp/tmp.gcPUdBLEyq
谢谢!
0 项奖励
1 个已接受解答
已接受的解答
694 次查看
注册日期: ‎08-27-2018
回复: 官方BSP 使用QEMU验证启动异常
转到解答
Hi, @weiyil
多谢上述回复
该问题已经解决,上述问题由系统环境导致,修改成英文环境后petalinux-boot启动正常.
10 条回复10
770 次查看
注册日期: ‎05-23-2018
转到解答
Hi, @fangzhengshu
在运行QEMU前有运行petalinux-package --prebuilt命令将prebuilt image打包吗?
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
761 次查看
注册日期: ‎08-27-2018
转到解答
Thank you for your reply, @weiyil
首先简要说明两种验证环境:一台PC为台式机服务器,其余三台PC为笔记本
使用BSP为官方提供:xilinx-zcu106-v2018.1-final.bsp
两台PC均未使用打包命令:petalinux-package --prebuilt
执行结果有差异:服务器可以正常通过qemu启动,笔记本PC均无法正常启动
两种环境存在验证差异可能受那些因素影响?
另外,使用官方BSP创建工程情况下,无法使用打包命令:petalinux-package --prebuilt
fangzheng@HP:~/workspace/app/xilinx-zcu106-2018.1$ petalinux-package --prebuilt
ERROR: Found existing pre-built folder, please use --force or --clean option to force update
  个人理解,官方BSP创建工程应该已经打包好了,不需要重新执行打包过程
另附服务器正确启动信息如下:
bfp@HP-AI:~/xilinx-zcu106-2018.1$ petalinux-boot --qemu --prebuilt 3
INFO: No DTB has been specified, use the default one "/home/bfp/xilinx-zcu106-2018.1/pre-built/linux/images/system.dtb".
INFO: Starting microblaze QEMU
INFO: Starting the above QEMU command in the background
INFO:  qemu-system-microblazeel -M microblaze-fdt   -display none -kernel /home/bfp/xilinx-zcu106-2018.1/pre-built/linux/images/pmu_rom_qemu_sha3.elf -device loader,file=/home/bfp/xilinx-zcu106-2018.1/pre-built/linux/images/pmufw.elf      -hw-dtb /home/bfp/xilinx-zcu106-2018.1/images/linux/zynqmp-qemu-multiarch-pmu.dtb -machine-path /tmp/tmp.Zzg33wYT7M -device loader,addr=0xfd1a0074,data=0x1011003,data-len=4 -device loader,addr=0xfd1a007C,data=0x1010f03,data-len=4
qemu-system-microblazeel: Failed to connect socket /tmp/tmp.Zzg33wYT7M/qemu-rport-_pmu@0: No such file or directory
qemu-system-microblazeel: info: QEMU waiting for connection on: disconnected:unix:/tmp/tmp.Zzg33wYT7M/qemu-rport-_pmu@0,server
INFO:  qemu-system-aarch64 -M arm-generic-fdt   -serial mon:stdio -serial /dev/null -display none -device loader,file=/home/bfp/xilinx-zcu106-2018.1/pre-built/linux/images/bl31.elf,cpu-num=0 -device loader,file=/home/bfp/xilinx-zcu106-2018.1/pre-built/linux/images/Image,addr=0x00080000 -device loader,file=/home/bfp/xilinx-zcu106-2018.1/pre-built/linux/images/system.dtb,addr=0x1407f000 -device loader,file=/home/bfp/xilinx-zcu106-2018.1/build/misc/linux-boot/linux-boot.elf -gdb tcp::9000 -dtb /home/bfp/xilinx-zcu106-2018.1/pre-built/linux/images/system.dtb  -net nic -net nic -net nic -net nic,vlan=1 -net user,vlan=1,tftp=/tftpboot    -hw-dtb /home/bfp/xilinx-zcu106-2018.1/images/linux/zynqmp-qemu-multiarch-arm.dtb -machine-path /tmp/tmp.Zzg33wYT7M -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true  -m 4G
qemu-system-aarch64: -net nic,vlan=1: 'vlan' is deprecated. Please use 'netdev' instead.
audio: Could not init `oss' audio driver
qemu-system-aarch64: warning: vlan 0 is not connected to host network
PMU Firmware 2018.1	Apr 17 2018   07:19:11
PMU_ROM Version: xpbr-v8.1.0-0
NOTICE:  ATF running on XCZUUNKN/QEMU v1/RTL0.0 at 0xfffea000
NOTICE:  BL31: Secure code at 0x60000000
NOTICE:  BL31: Non secure code at 0x10080000
NOTICE:  BL31: v1.4(release):xilinx-v2017.4-1351-gdf4a7e97
NOTICE:  BL31: Built : 13:11:30, Apr 17 2018
[    0.000000] Booting Linux on physical CPU 0x0
0 项奖励
753 次查看
注册日期: ‎05-23-2018
转到解答
Hi, @fangzhengshu
可以看到程序报错是因为没有找到device tree blob(dtb)文件,在pre-built/linux/images/下是否有相应的dtb文件?
0 项奖励
747 次查看
注册日期: ‎08-27-2018
转到解答
Hi, @weiyil
目前可以确认system.dtb是存在的
比较异常的几点如下:
  1. -dtb参数为何未指向pre-built/linux/images/system.dtb,而是指向/tmp/tmp.kJhC5bGSev
  2. -machine-path参数同样也是指向/tmp/tmp.cJsfjP2I20
  3. 通过正确执行时的日志信息看,两种情况下的命令有差异,正确时执行了qemu-system-microblazeel,错误时一直执行的qemu-system-aarch64,这种命令不一致的情况是由什么原因导致的?
谢谢!
下附pre-built目录结构如下:
fangzheng@HP:~/workspace/app/xilinx-zcu106-2018.1/pre-built$ tree -L 3
└── linux
    ├── etc
    ├── images
    │   ├── bl31.bin
    │   ├── bl31.elf
    │   ├── BOOT.BIN
    │   ├── Image
    │   ├── image.ub
    │   ├── openamp.dtb
    │   ├── pmufw.elf
    │   ├── pmu_rom_qemu_sha3.elf
    │   ├── rootfs.bin
    │   ├── rootfs.cpio.bz2
    │   ├── rootfs.cpio.gz
    │   ├── rootfs.ext3.bz2
    │   ├── rootfs.its
    │   ├── rootfs.manifest
    │   ├── rootfs.tar.bz2
    │   ├── rootfs.tar.gz
    │   ├── rootfs.testdata.json
    │   ├── system.bit
    │   ├── system.dtb
    │   ├── System.map.linux
    │   ├── u-boot.bin
    │   ├── u-boot.elf
    │   ├── vmlinux
    │   ├── xen.dtb
    │   ├── xen-Image
    │   ├── xen-openamp.dtb
    │   ├── xen-qemu.dtb
    │   ├── xen-rootfs.cpio.gz
    │   ├── xen-rootfs.cpio.gz.u-boot
    │   ├── xen.ub
    │   ├── zynqmp_fsbl.elf
    │   ├── zynqmp-qemu-arm.dtb
    │   ├── zynqmp-qemu-multiarch-arm.dtb
    │   └── zynqmp-qemu-multiarch-pmu.dtb
    └── implementation
        └── download.bit
4 directories, 35 files
0 项奖励
743 次查看
注册日期: ‎08-27-2018
转到解答
Hi, @weiyil
目前环境搭建过程仅参考Petalinux SDK的安装说明,如果要运行BSP创建的工程,是否还存在其他依赖?
另外,为了尝试解决dtb问题,手动指定qemu-args参数,执行仍然不能成功:
fangzheng@HP:~/workspace/app/xilinx-zcu106-2018.1$ petalinux-boot --qemu --prebuilt 3 --qemu-args "--dtb ./pre-built/linux/images/system.dtb"
INFO:  qemu-system-aarch64 -M arm-generic-fdt   -display none -device loader,file=/home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/pmu_rom_qemu_sha3.elf,cpu-num=0 -gdb tcp::9000 -dtb /tmp/tmp.XWFjWfqUyY    --dtb ./pre-built/linux/images/system.dtb -hw-dtb /mnt/workspace/app/xilinx-zcu106-2018.1/images/linux/zynqmp-qemu-multiarch-arm.dtb -machine-path /tmp/tmp.uFH4VUoTWP -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true  -m 4G
qemu-system-aarch64: Failed to connect socket /tmp/tmp.uFH4VUoTWP/qemu-rport-_pmu@0: No such file or directory
qemu-system-aarch64: info: QEMU waiting for connection on: disconnected:unix:/tmp/tmp.uFH4VUoTWP/qemu-rport-_pmu@0,server
实际上socket文件是存在的:
fangzheng@HP:/tmp/tmp.uFH4VUoTWP$ ls -l
总用量 0
srwxrwxr-x 1 fangzheng fangzheng 0 8月  28 16:00 qemu-rport-_pmu@0
0 项奖励
736 次查看
注册日期: ‎05-23-2018
转到解答
Hi, @fangzhengshu
您可以尝试一下通过手动输入命令的方式启动QEMU,并将-dtb等参数设置到正确的路径上。
0 项奖励
731 次查看
注册日期: ‎08-27-2018
转到解答
@weiyil
请查看前一条回复,已尝试手动指定dtb,同样存在问题
0 项奖励
726 次查看
注册日期: ‎05-23-2018
转到解答
Hi, @fangzhengshu
指的是不要通过petalinux命令来运行QEMU,尝试直接运行QEMU的命令。另外指定dtb文件的命令参数为“-dtb"而不是"--dtb"。
0 项奖励
716 次查看
注册日期: ‎08-27-2018
转到解答
Hi,@weiyil
直接使用qemu-system-aarch64命令启动执行结果仍然存在异常:
fangzheng@HP:~/workspace/app/xilinx-zcu106-2018.1$ qemu-system-aarch64 -M arm-generic-fdt   -display none -device loader,file=/home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/pmu_rom_qemu_sha3.elf,cpu-num=0 -gdb tcp::9000 --dtb /home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/system.dtb -hw-dtb /mnt/workspace/app/xilinx-zcu106-2018.1/images/linux/zynqmp-qemu-multiarch-arm.dtb -machine-path /tmp/petalinux-qemu -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true -m 4G
qemu-system-aarch64: Failed to connect socket /tmp/petalinux-qemu/qemu-rport-_pmu@0: Connection refused
qemu-system-aarch64: info: QEMU waiting for connection on: disconnected:unix:/tmp/petalinux-qemu/qemu-rport-_pmu@0,server
^C
fangzheng@HP:~/workspace/app/xilinx-zcu106-2018.1$ file /home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/system.dtb/home/fangzheng/workspace/app/xilinx-zcu106-2018.1/pre-built/linux/images/system.dtb: Device Tree Blob version 17, size=42129, boot CPU=0, string block size=2377, DT structure block size=35472
错误信息有所变化,socket拒绝连接
仅执行上述命令是否存在不足?
因为正常执行的命令信息第一条就是qemu-system-microblazeel的信息
0 项奖励
695 次查看
注册日期: ‎08-27-2018
转到解答
Hi, @weiyil
多谢上述回复
