取消
显示结果
搜索替代
您的意思是:
Visitor qrobot
273 次查看
注册日期: ‎12-17-2018
xilinx petalinx 17.03 linux 工程在zc7030上 无法进入内核,停止在 Sarting Kernel.....
xilinx ZNYQ 7030上,petalinx 17.3的工程无法进入内核,内核停止在 Sarting Kernel..... ,没有任何信息打出:
U-Boot 2017.01 (Jan 02 2019 - 17:43:46 +0800)
Board: Xilinx Zynq
DRAM: ECC disabled 512 MiB
MMC: Card did not respond to voltage select!
sdhci@e0101000 - probe failed: -95
sdhci@e0100000: 0 (SD)Card did not respond to voltage select!
** Unable to use mmc 0:2 for loading the env **
Using default environment
In: serial
Out: serial
Err: serial
U-BOOT for ax7030
Device: sdhci@e0100000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
3761576 bytes read in 639 ms (5.6 MiB/s)
Manufacturer ID: 3
OEM: 5344
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
reading system.dtb
13881 bytes read in 18 ms (752.9 KiB/s)
Using 'conf@2' configuration
Verifying Hash Integrity ... OK
Trying 'kernel@0' kernel subimage
Description: Linux Kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x100000d4
Data Size: 3746400 Bytes = 3.6 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha1
Hash value: 3a2f0e7220b97e4076822acb72341ca2f46307f3
## Flattened Device Tree blob at 11800000
Booting using the fdt blob at 0x11800000
Loading Kernel Image ... OK
Loading Device Tree to 07ff9000, end 07fff638 ... OK
Starting kernel ...
同样按官方文档UG1144(2017.3)建的工程在zynq7020上能够正常运行,按同样的方法建的工程且在zynq7030上无法驱动内核!
0 项奖励
1 条回复1
Scholar xilinxacct
241 次查看
注册日期: ‎10-24-2018
回复: xilinx petalinx 17.03 linux 工程在zc7030上 无法进入内核,停止在 Sarting Kernel.....
@qrobot
Did you re-target the board? (e.g. select the 7030 as the board you want to implement)?
