取消
显示结果
显示  仅  | 搜索替代
您的意思是:
179 次查看
注册日期: ‎05-26-2020
ZCU104使用官方镜像烧录SD卡启动失败
[ 6.804756] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
[ 6.812010] pca953x 0-0020: Linked as a consumer to regulator.0
[ 6.819388] at24 2-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 6.826127] i2c i2c-0: Added multiplexed i2c bus 2
[ 6.831124] i2c i2c-0: Added multiplexed i2c bus 3
[ 6.852515] random: fast init done
[ 7.099082] pmbus 4-004d: PMBus status register not found
[ 7.225735] [drm] Cannot find any crtc or sizes
[ 10.085732] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 11.109727] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 12.133730] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 13.157730] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 14.181730] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 15.205729] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 16.229729] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 17.253729] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 18.277734] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 19.301729] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 20.325730] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 20.331980] i2c i2c-0: Added multiplexed i2c bus 4
[ 21.349727] cdns-i2c ff030000.i2c: timeout waiting on completion
[ 21.355734] ina2xx 5-0040: error configuring the device: -110
[ 21.361525] i2c i2c-0: Added multiplexed i2c bus 5
[ 21.366439] i2c i2c-0: Added multiplexed i2c bus 6
[ 21.371351] i2c i2c-0: Added multiplexed i2c bus 7
[ 21.376262] i2c i2c-0: Added multiplexed i2c bus 8
[ 21.381176] i2c i2c-0: Added multiplexed i2c bus 9
[ 21.385969] pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
[ 21.393557] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 32
[ 21.399906] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 60s
[ 21.409104] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 10s
如图所示,求大神解决
0 项奖励
2 回复数
119 次查看
注册日期: ‎09-14-2018
@hiehie
hi
1. 你用的什么镜像?麻烦提供下链接。
2. 建议附下完整启动log.
如果帖子有帮助,别忘“接受为解决方案”或“奖励”。谢谢!
Don't forget to "Accept as solution" or "Kudo" if it helps. Thanks!
0 项奖励
113 次查看
注册日期: ‎05-26-2020
已经启动完成了,可以帮我看下,编译PYNQ出现这种情况的问题吗
hxf@ubuntu:~/work/PYNQ/sdbuild$
hxf@ubuntu:~/work/PYNQ/sdbuild$ make
/opt/qemu/bin//qemu-aarch64-static -version | fgrep 4.0.0
qemu-aarch64 version 4.0.0 /opt/qemu/bin//qemu-arm-static -version | fgrep 4.0.0
qemu-arm version 4.0.0 vivado -version | fgrep 2019.1
Vivado v2019.1 (64-bit) xsdk -version | fgrep 2019.1
****** SDK v2019.1 (64-bit)
which petalinux-config | fgrep 2019.1
Makefile:339: recipe for target 'checkenv' failed
make: *** [checkenv] Error 1
出现checkenv错误问题,petalinux已安装,还是检测不到?
0 项奖励
