修改时间 11-11-2020 05:07 PM
Initialization done, programming the memory
Using default mini u-boot image file - C:/Xilinx/Vitis/2019.2/data\xicom\cfgmem\uboot\zynq_qspi_x4_single.bin
===== mrd->addr=0xF800025C, data=0x00000000 =====
BOOT_MODE REG = 0x00000000
Downloading FSBL...
Running FSBL...
Finished running FSBL.
===== mrd->addr=0xF8000110, data=0x000FA220 =====
READ: ARM_PLL_CFG (0xF8000110) = 0x000FA220
===== mrd->addr=0xF8000100, data=0x00028008 =====
READ: ARM_PLL_CTRL (0xF8000100) = 0x00028008
===== mrd->addr=0xF8000120, data=0x1F000200 =====
READ: ARM_CLK_CTRL (0xF8000120) = 0x1F000200
===== mrd->addr=0xF8000118, data=0x000FA240 =====
READ: IO_PLL_CFG (0xF8000118) = 0x000FA240
===== mrd->addr=0xF8000108, data=0x00030008 =====
READ: IO_PLL_CTRL (0xF8000108) = 0x00030008
Info: Remapping 256KB of on-chip-memory RAM memory to 0xFFFC0000.
===== mrd->addr=0xF8000008, data=0x00000000 =====
===== mwr->addr=0xF8000008, data=0x0000DF0D =====
MASKWRITE: addr=0xF8000008, mask=0x0000FFFF, newData=0x0000DF0D
===== mwr->addr=0xF8000910, data=0x000001FF =====
===== mrd->addr=0xF8000004, data=0x00000000 =====
===== mwr->addr=0xF8000004, data=0x0000767B =====
MASKWRITE: addr=0xF8000004, mask=0x0000FFFF, newData=0x0000767B
Problem in running uboot
Flash programming initialization failed.
ERROR: Flash Operation Failed
这是什么原因呢?
修改时间 11-12-2020 02:56 PM
Hi @arcking0
建议先根据checkList检查下看看。
https://www.xilinx.com/support/answers/59174.html
供参考。
如果帖子有帮助,别忘“接受为解决方案”或“奖励”。谢谢!
Don't forget to "Accept as solution" or "Kudo" if it helps. Thanks!
