Interfacing xadc to the zedboard
I want to implement the FFT  spectrum of input square or sine wave project in zedboard below is the PDF attached  from  page 4 to page 16(audio processing part implemented in nexys4 board) which i wanted to implement in zedboard (not in nexys4 board)  with sine or square wave input, now my question is how to  interface Xadc with zedboard and send the samples to FFT please do let me know once refer that PDF and do let me know please.
below is the link povided for coding part of audio processing part but i got stuck to interface xadc with zedboard and to send samples to the FFT.
 https://github.com/mitchgu/GuitarHeroFFE
Re: Interfacing xadc to the zedboard
A good place for you to start is with the XADC user guide
http://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf
This will detail the XADC, it's operating modes and the analog inputs.
Next it would make sense to look at this XAPP
http://www.xilinx.com/support/documentation/application_notes/xapp795-driving-xadc.pdf
It will detail a proper way to acquire the signals at the analog input.
The next step would be to look closely at what is available for the Zedboard so you can connect the signal to the XADC.
