Visitor jukidav
Issue with Xilinx-7 series SERDES output
I am trying to simulate Xilinx-7 series SERDES. The SEREDES is configured as SDR 8 bit mode, single CE.The clkDiv, clk,Enable and data are generated as in attached figure. As per documentation data is expected on Q8. But I am getting it on Q2. rest is high for more than two clkDiv cycles. I am getting the following pattern at o/p:
Q2,Q1,Q8,Q7,...Q3.
Is anybody comeacross this simulation findings, kindly help to clarify what is the mistake.
Jayaraj
Community Manager
Community Manager
Re: Issue with Xilinx-7 series SERDES output
Hi @jukidav
When you simulate you should be able to see a signal on the ISERDES called the clkdiv_int and the word aligned of the serial data is determined by this clock.
For a simulation previously I had drawn up the alignment, the Q follows the clkdiv_int alignment not the clkdiv. This would be the same in HW
Visitor jukidav
Thank you for the reply. However when I simulate Xilinx-7 series SERDES, I could not able to see clkdiv_int signal. Kindly let me know which application note I need to refer for this. I am referring UG471.
Jayaraj
