Observer penlaebruno
[Netlist 29-85] warning on PLL_ADV instance
Hi all,
I am porting a design from Spartan6/ISE to Artix7/Vivado.
On some PLL instantiation, I get the following critical warning: [Netlist 29-85] One or more of the DRP ports of PLL_ADV instance 'U_CommonTopLevel/u_pll_adv' are connected to nets. The DRP ports are not supported for direct mapping to MMCM due to address changes, and must remain unconnected. DRP ports include DO, DRDY, DADDR, DCLK, DEN, DI, and DWE.
But in the instantiation all DRP ports are unconnected:
u_pll_adv
.CLKFBIN (clkfbout_clkfbin),
.CLKINSEL (1'b1),
.CLKIN1 (sys_clk_ibufg),
.CLKIN2 (1'b0),
.REL (1'b0),
.RST (1'b0),
.CLKFBOUT (clkfbout_clkfbin),
.CLKOUT0 (clk_adc)
Best regards.
Re: [Netlist 29-85] warning on PLL_ADV instance
Hi, @penlaebruno ,
I understand that you intend to keep the source code same for different devices, but it is only suitable for source code with no relationship with the device (General purpose code).
Since you are using the bottom level primitive(which is quite different for SP6/A7) in your source code,  these primitives are not suitable for portable purpose.
In my opinion, Retargeting primitives with large difference is a high risk action.
HI, @penlaebruno ,
You can try to regenerate all MMCM/PLL IPs in the Artix7/Vivado Project and run the flow again.
Thanks, that was my backup plan.
This is not ideal for me since I want to keep the code working on both target and regenerating the MCMM will create a different instance depending on the target.
Hi, @penlaebruno ,
