XQ7A200T-1RB676M ESD and MSL ratings
I work for an Aerospace company and we need to confirm/identify the MSL and ESD ratings for P/N XQ7A200T-1RB676M.
Can you please provide this information?
Re: XQ7A200T-1RB676M ESD and MSL ratings
So,
You should contact your local Xilinx authorized distributor.
All specifications you are asking for are in the data sheet, and the ug116 reliability report, however.
Also:
https://www.xilinx.com/support/answers/1890.html
Thank you for your response. The link you provided, however, links to two broken "404 not found" links. I was not able to find the information in the product datasheet either when I checked. I used CRTL+F on the document for "ESD" and "MSL" with no hits.
I need to confirm MSL and ESD ratings for an entire BOM in the next few days. The datasheet for an FPGA is large, as I'm sure you know, so if the information is in there it must be relatively embedded. I am not familiar with the ugg116 reliability report...is this something found on the Xilinx site?
https://www.xilinx.com/support/documentation/user_guides/ug116.pdf
and
https://www.xilinx.com/support/documentation/data_sheets/ds181_Artix_7_Data_Sheet.pdf
and
https://www.xilinx.com/support/documentation/data_sheets/ds185-7SeriesQ-Overview.pdf
all found using the search (magnifying glass) in the top right hand corner of this page!  Note search engines WILL NOT FIND ANY of these!  You MUST use the xilinx.com search.  Do not ask me why, as I do not pretend to know why anyone would block search engines from helping find documents that (might) increase sales, make customers happy, and simplify support.
