Visitor mhanuel
Zynq-700 LVDS camera interface question
I need to interface a camera IC interface from TI that outputs LVDS signal, the device is
sn65lvds315, here is a block diagram
Can somehow comment in general the steps I might need to do, I understand I need to deserialize the LVDS data as first step.
I have read that there is a way to capture the frame flags  but that might only apply to ADC data which is 14 or 16 bit, since this is a stream, I might need to transfer everything using DMA to DDR memory, but maybe is possible I can place some logic to compare the SOF and EOF values that the transceiver output and generate an interrupt to inform the processor. ?
Will appreciate if someone can point me in the right direction.
Re: Zynq-700 LVDS camera interface question
Did you take a look at xapp585 this shows 7:1 deserialisation? It will show you how we do per bit deskew and frame alignment?
Scholar watari
Hi @mhanuel
As @klumsde already mentioned before, I suggest to refer xapp585 and xapp1315.
You can understand how to resolve your request.
xapp585 (for 7 series and zynq 7 series)
https://www.xilinx.com/support/documentation/application_notes/xapp585-lvds-source-synch-serdes-clock-multiplication.pdf
xapp1315 (ultra scale and ultra scale +)
https://www.xilinx.com/support/documentation/application_notes/xapp1315-lvds-source-synch-serdes-clock-multiplication.pdf
Also, if you want to transfer the stream video data to DRAM, I suggest to use the following IPs.
- Video-in to AXI4Stream
- Video Timing Generator
- VDMA
- AXI4Stream to Video-out (if necessary)
If you have another question, would you post new thread on "Video" section ?
