AXI_QUAD_SPI in Kintex 7
I have a working design in Kintex-7 410T. This design includes number of SERDES and a DDR3 interface. The Vivado flow goes smoothly. The bit stream is generated and working in my lab test.
Now, I want to add the AXI_QUAD_SPI IP (quad mode) in order to read and write the attached configuration Micron SPI flash. I follow the AXI_QUAD_SPI design example:
1. Instantiate the AXI_QUAD_SPI with STARTUPE2 enable.
2. Connect the io0_i/o/t, io1_i/o/t, io2_i/o/t, io3_i/o/t and ss_i/o/t to the IOBUF
3. Adding pin locations and buffer type (LVCMOS25) to my top level xdc constraint file.
Synthesis completed. But I got error during Implementation phase. The error message is as follow:
Phase 1.1 IO Placement/ Clock Placement/ Build Placer Device
INFO: [Timing 38-35] Done setting XDC timing constraints.
ERROR: [Place 30-374] IO placer failed to find a solution
Below is the partial placement that can be analyzed to see if any constraint modifications will make the IO placement problem easier to solve.
<In the list are 113 DDR3 related pins and a pair of clock inputs>
I suspect the new quad spi flash pins cause some conflict and make Vivado to unplace those DDR3 pins. DDR3 constraints is specified inside DDR3 xdc, generated by Vivado.
I appreciate any help.
TD
I found the root cause of my Implementation issue:
Somehow, my Vivado generated mig_ddr3 xdc file got messed up and cause this issue.
TD
