olkhramus
About statement in bootgen file
I see the statement in the BIF file related to bootloader:
[bootloader, destination_device = pl].\zynqmp_fsbl.elf
Is it correct ? I don't expect to see in the "destination_device" field the programmable ligic (pl).
glena
the FSBL is required for all boots - bare metal and Linux.    Refer to the Booting Linux section of UG1283
glena
That is not correct.  I would expect:
[bootloader, destination_cpu=a53-0] zynqmp_fsbl.elf
Refer to UG1283
How was this bif generated?
olkhramus
It came from the external team.
If I understood correctly UG1283 in the bootlader partition can be present only cpu:  a53 or r5. Isn't?
glena
The bootloader attribute applies only for the FSBL.   The FSBL can be built to target either the A53 or the R5
olkhramus
I guess it related for baremetal application as well. Isn't?
glena
