Can't program QSPI Flash, no DDR
xc7z020clg400-2, Vivado/SDK 2017.4. I've been following this: http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Boot+-+Booting+and+Running+Without+External+Memory+Tech+Tip, as well as this post: https://forums.xilinx.com/t5/Embedded-Boot-and-Configuration/Can-t-flash-QSPI/td-p/813536. I'm able to directly write and read the flash using the xqspips_g128_flash_example, so I know that it isn't a connection issue. We are using a Spansion S25FL256L, as a our flash chip which I know isn't directly compatible, however it is identified by Vivado as the Spansion S25FL256S (which is a compatible chip). Any help at this point is appreciated. I've attempted to program flash in 2016.4 without luck, and decided to install 2017.4 in order to see if the two examples above would work, which they don't. This is the output when I run the "Program Flash" utility in SDK:
****** Xilinx Program Flash
****** Program Flash v2017.4 (64-bit)
**** SW Build 2086221 on Fri Dec 15 20:55:39 MST 2017
** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
Connecting to hw_server @ TCP:127.0.0.1:3121
Connected to hw_server @ TCP:127.0.0.1:3121
Available targets and devices:
Target 0 : jsn1
Target 1 : jsn-DLC10-000017df129e01
Target 2 : jsn2
Device 0: jsn-DLC10-000017df129e01-4ba00477-0
Device 1: jsn-DLC10-000017df129e01-23727093-0
Retrieving Flash info...
Initialization done, programming the memory
===== mrd->addr=0xF800025C, data=0x00000000 =====
BOOT_MODE REG = 0x00000000
===== mrd->addr=0xF8000008, data=0x00000000 =====
===== mwr->addr=0xF8000008, data=0x0000DF0D =====
MASKWRITE: addr=0xF8000008, mask=0x0000FFFF, newData=0x0000DF0D
===== mrd->addr=0xF8000110, data=0x00177EA0 =====
===== mwr->addr=0xF8000110, data=0x00177EA0 =====
MASKWRITE: addr=0xF8000110, mask=0x003FFFF0, newData=0x00177EA0
===== mrd->addr=0xF8000100, data=0x0001A008 =====
===== mwr->addr=0xF8000100, data=0x0001A008 =====
MASKWRITE: addr=0xF8000100, mask=0x0007F000, newData=0x0001A008
===== mwr->addr=0xF8000100, data=0x0001A010 =====
MASKWRITE: addr=0xF8000100, mask=0x00000018, newData=0x0001A010
===== mrd->addr=0xF8000100, data=0x0001A010 =====
===== mwr->addr=0xF8000100, data=0x0001A011 =====
MASKWRITE: addr=0xF8000100, mask=0x00000001, newData=0x0001A011
===== mrd->addr=0xF8000100, data=0x0001A011 =====
MASKWRITE: addr=0xF8000100, mask=0x00000001, newData=0x0001A010
===== mrd->addr=0xF800010C, data=0x0000003F =====
READ: addr=0xF800010C, Data=0x0000003F
===== mwr->addr=0xF8000100, data=0x0001A000 =====
MASKWRITE: addr=0xF8000100, mask=0x00000010, newData=0x0001A000
===== mrd->addr=0xF8000120, data=0x1F000400 =====
===== mwr->addr=0xF8000120, data=0x1F000400 =====
MASKWRITE: addr=0xF8000120, mask=0x1F003F30, newData=0x1F000400
===== mrd->addr=0xF8000118, data=0x00177EA0 =====
===== mwr->addr=0xF8000118, data=0x00177EA0 =====
MASKWRITE: addr=0xF8000118, mask=0x003FFFF0, newData=0x00177EA0
===== mrd->addr=0xF8000108, data=0x0001A008 =====
===== mwr->addr=0xF8000108, data=0x0001A008 =====
MASKWRITE: addr=0xF8000108, mask=0x0007F000, newData=0x0001A008
===== mwr->addr=0xF8000108, data=0x0001A010 =====
MASKWRITE: addr=0xF8000108, mask=0x00000018, newData=0x0001A010
===== mrd->addr=0xF8000108, data=0x0001A010 =====
===== mwr->addr=0xF8000108, data=0x0001A011 =====
MASKWRITE: addr=0xF8000108, mask=0x00000001, newData=0x0001A011
===== mrd->addr=0xF8000108, data=0x0001A011 =====
MASKWRITE: addr=0xF8000108, mask=0x00000001, newData=0x0001A010
===== mwr->addr=0xF8000108, data=0x0001A000 =====
MASKWRITE: addr=0xF8000108, mask=0x00000010, newData=0x0001A000
===== mrd->addr=0xF8000004, data=0x00000000 =====
===== mwr->addr=0xF8000004, data=0x0000767B =====
MASKWRITE: addr=0xF8000004, mask=0x0000FFFF, newData=0x0000767B
Info: Remapping 256KB of on-chip-memory RAM memory to 0xFFFC0000.
===== mwr->addr=0xF8000910, data=0x000001FF =====
U-Boot 2017.01-00148-g4c61f9b-dirty (Sep 22 2017 - 09:50:06 -0600), Build: jenkins-mini_uboot-mini_uboot-218
Model: Zynq CSE QSPI Board
Board: Xilinx Zynq
DRAM: ECC disabled 256 KiB
WARNING: Caches not enabled
Using default environment
In: dcc
Out: dcc
Err: dcc
Board: Xilinx Zynq
Zynq> sf probe 0 10000000 0
SF: unrecognized JEDEC id bytes: 01, 60, 19
Failed to initialize SPI flash at 0:0 (error -2)
Zynq> Sector size = 0.
Performing Erase Operation...
sf erase 0 5E0000
No SPI flash selected. Please run `sf probe'
Zynq> Erase Operation successful.
INFO: [Xicom 50-44] Elapsed time = 0 sec.
Performing Program Operation...
0%...sf write FFFC0000 0 20000
Zynq> sf write FFFC0000 20000 20000
Zynq> sf write FFFC0000 40000 20000
Zynq> sf write FFFC0000 60000 20000
Zynq> sf write FFFC0000 80000 20000
Zynq> 10%...sf write FFFC0000 A0000 20000
Zynq> sf write FFFC0000 C0000 20000
Zynq> sf write FFFC0000 E0000 20000
Zynq> sf write FFFC0000 100000 20000
Zynq> sf write FFFC0000 120000 20000
Zynq> sf write FFFC0000 140000 20000
Zynq> sf write FFFC0000 160000 20000
Zynq> sf write FFFC0000 180000 20000
Zynq> sf write FFFC0000 1A0000 20000
Zynq> 30%...sf write FFFC0000 1C0000 20000
Zynq> sf write FFFC0000 1E0000 20000
Zynq> sf write FFFC0000 200000 20000
Zynq> sf write FFFC0000 220000 20000
Zynq> sf write FFFC0000 240000 20000
Zynq> sf write FFFC0000 260000 20000
Zynq> sf write FFFC0000 280000 20000
Zynq> sf write FFFC0000 2A0000 20000
Zynq> sf write FFFC0000 2C0000 20000
Zynq> 50%...sf write FFFC0000 2E0000 20000
Zynq> sf write FFFC0000 300000 20000
Zynq> sf write FFFC0000 320000 20000
Zynq> sf write FFFC0000 340000 20000
Zynq> sf write FFFC0000 360000 20000
Zynq> 60%...sf write FFFC0000 380000 20000
Zynq> sf write FFFC0000 3A0000 20000
Zynq> sf write FFFC0000 3C0000 20000
Zynq> sf write FFFC0000 3E0000 20000
Zynq> sf write FFFC0000 400000 20000
Zynq> sf write FFFC0000 420000 20000
Zynq> sf write FFFC0000 440000 20000
Zynq> sf write FFFC0000 460000 20000
Zynq> sf write FFFC0000 480000 20000
Zynq> 80%...sf write FFFC0000 4A0000 20000
Zynq> sf write FFFC0000 4C0000 20000
Zynq> sf write FFFC0000 4E0000 20000
Zynq> sf write FFFC0000 500000 20000
Zynq> sf write FFFC0000 520000 20000
Zynq> sf write FFFC0000 540000 20000
Zynq> sf write FFFC0000 560000 20000
Zynq> sf write FFFC0000 580000 20000
Zynq> sf write FFFC0000 5A0000 20000
Zynq> 100%
sf write FFFC0000 5C0000 1BB00
Zynq> Program Operation successful.
INFO: [Xicom 50-44] Elapsed time = 96 sec.
Performing Verify Operation...
0%...sf read FFFC0000 0 10000
Zynq> cmp.b FFFC0000 FFFD0000 10000
byte at 0xfffc0000 (0x0) != byte at 0xfffd0000 (0xfe)
Total of 0 byte(s) were the same
Zynq> INFO: [Xicom 50-44] Elapsed time = 1 sec.
Verify Operation unsuccessful.
ERROR: Flash Operation Failed
Re: Can't program QSPI Flash, no DDR
In the case without DDR, you'll want to build the Zynq_cse_qspi platform wiki u-Boot.   There may be some system specific edits you will need to make from there.
Also, I have the Environment Variables set: XIL_CSE_ZYNQ_UBOOT_QSPI_FREQ_HZ = 10000000, and XIL_CSE_ZYNQ_DISPLAY_UBOOT_MESSAGES = 1. XIP_mode, and Standalone OS.
Can you try this in 2018.1?
Haven't tried 2018.1, are there any updates regarding programming flash in this version of SDK?
Yes, 2018.1 uses a new mini uBoot, the  XIL_CSE_ZYNQ_UBOOT_QSPI_FREQ_HZ = 10000000 env variable is no longer necessary.
I'll try this. Will update after.
Using 2018.1 didn't make a difference. I also attempted to change the spi.cfg and modify the S25FL256S to be the IDCODE that corresponds to my flash, 01 60 19, but it seems that modifying this file didn't change anything. Is there any way to trick the tools into believing that my IDCODE corresponds to a known device?
please post the programming log.   In the sf probe command, is your QSPI device found?
I'm sorry, I missed the comment that you are not using a supported QSPI device.  You'll need to program your QSPI manually via uBoot.   You can refer to AR62743 for how to attempt to program unsupported QSPI devices
Does that mean that we need to build u-boot manually? Is there any other way to gain access to the sf_params.c and add our device?
You can try one of the pre-built uBoots at Wiki_Zynq+Releases
Ours is a custom board, so I would need to modify the pre-built image. But this isn't possible with the bin and elf files that are given. Or is it? Sorry pretty new to this stuff.
The .bin and .elf files are compiled, so you will need to modify uBoot.    First verify your QSPI device is compatible with the Zynq BootROM using the example in AR62743.   You may need to contact Spansion  to see if your device aliases to a supported JEDEC id.
I've been attempting to build u-boot and when I do make inside the uboot directory, after make zynq_zc702_defconfig, it fails due to bad value (armv5) for -march= switch. Not sure how to get around this. This is using the uboot from git as well as the newest dtc.
Which tagged version of uBoot are you using?
Not sure how to check that, but it's the latest one on the Xilinx u-boot GitHub. edit: 2018.1
When you download, check the branch.   Don't use the Master, use a tagged branch to match the tool chain version you are using.
2018.1
After including CROSS_COMPILE=arm-none-eabi- when I build u-boot, I now receive the message: *** Your GCC is older than 6.0 and is not supported. I checked the version of arm-none-eabi-gcc and it says:
arm-none-eabi-gcc (Linaro GCC 7.2-2017.11-rc1) 7.2.1 20171011
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
My normal gcc is version 6.4.0-17ubuntu1~16.04. Not sure where to go from here.
I was able to produce a u-boot.elf. Now what do I do? How can I use what was produced to program the flash?
Go to this wiki page http://www.wiki.xilinx.com/Programming+QSPI+from+U-boot+ZC702
Will this still work without ddr?
Because I tried the u-boot approach, and wanted to dow my mcs file into the QSPI linear address (0xfc000000) and it says that QSPI is disabled. And all the examples I've seen dow the bin/mcs file into the ddr address (0x08000000).
I know that this thread has already solved, but I can suggest
zynq_flash project for erase/write/read QSPI flash of Zynq devices.
In this case the FSBL/Uboot wont be used during the flashing, which makes FSBL simpler.
