Determine device using Linux, ZU2EG vs ZU3EG
We’re programming the PL on the Ultrascale+ at run-time from Linux.  We’d like to write the code so that it can support either the ZU2EG or ZU3EG and load the correct corresponding bitstream.  We’re trying to determine if there’s a way to query the part type from Linux.
In the technical reference manual, I see that those two parts have different IDCODEs, but most of the documentation talks about reading the IDCODE register from JTAG.  Is there a way to read the IDCODE from Linux running on the PS.  If not, then is there a different way firmware could determine what part type it’s running on?
Hi @400garrison,
You can read back the contents of FPGA configuration registers using fpgautil -r command to know the IDCODE.
Please check this wiki.
Thanks & Regards
Anil B
Hi @400garrison,
Thanks & Regards
Anil B
