How to SD Card with Boot Image
Hello, I created a Bar-Metal Hello World and have created a Boot Image. How do I burn the image to an SD card? I am using the latest Vitis tool set.
Thank you,
Joe
Hi @joe306
If you are using the default configuration of Vitis and you are building the full system (not only the application), Vitis should create a BOOT.BIN file.
So just copy it to your SDCard and... tadam... the board should boot (assuming the boot pins are set to SD card)
Florent
Hi @joe306
Florent
Thank you very much.
