How to merge multiple binaries for flashing using Vitis IDE
We are doing a flashing experiment on Xilinx EVK. We want to flash BOOT.BIN, uImage and .dtb files.
Exp:
We tried to merge all the binaries to create one single .bin file using Create Boot Image under Xilinux from the top menu. We are using Vitis IDE tool for this.
After creating the BOOT.bin we tried to flash to QSPI memory. We could flash the BOOT.bin but EVK is not booting with this experiment.
What is the correct procedure to merge the multiple binaries?
or Is there any way to flash the multiple binaries (BOOT.BIN, uImage and .dtb files)?
Thank you,
Prathibha
Hi @Prathibha ,
Please refer to this wiki and create a bif file with your partitions. Then generate a final boot image using bootgen command given in wiki from xsct console which is part of the Vitis tool.
Thanks & Regards
Anil B
Hello Anil,
Thank you for the reply. We are able to merge the binaries, flash and boot the EVK now.
Thank you,
Prathibha
Hi @Prathibha,
Good to know that you are able to merge the binaries! Can you please close this thread as accept a solution to help others?
Thanks & Regards
Anil B
