PS_Error_out
Using a Zynq ultrascale, on power up I have a PS_ERROR_Out.  The PMU global register values are:
0xFFD80530  0x00000000
0xFFD8040    0x01000000
I also have:  PSU - RPU - Reset
                               APU- No Power
Cause of issue ended up being power supply sequencing.   If PS_POR_B was brought momentarily low after all the power was up, the PS_ERROR_OUT extinguished and the error codes cleared.  Now we are charing the DDR4 calibration.
Bit 24 of Error_Status_2 is the PMU_SERVCE bit.  It looks like you have a PMU interrupt that is not getting serviced.  This is often caused by not having GPI signlas properly terminated
What about the APU - No power?
We also have FPD - No Power,  is this a result of the possible PMU interrupt issue?
Are you providing APU power?  Do you have any PMU GPIs defined in Vivado?   If you do and they are not terminated on your board they can trigger an interrupt before the PMUFW is loaded - that is the normal cause of this error.   What board are you using?
It is a custom derivative of the AVNET SOM. Unfortunately, We do not know how to define the PMU GPI's in Vivado, can you supply a reference ?
This are defined in the PCW (Processor Configuration Wizard) in Vivado.  In the I/O Configuration tab, check what you have enabled under PMU.  AR66436 shows a screenshot and discusses some aspects of PMU interrupts.
The PMU box is unchecked.  when checked, we get this:
In our design, MIO 26 - 31 and MIO34 - 37 are floating.
What is in your bif?   You could check the PMU IRQ_PENDING register (0xFFD40034) that should tell you what interrupt is triggering.
