Running separate binaries on ZynqMP cores a53-0 & a53-1
I have inherited a system running on a ZCU706 (Zynq-7000) and have the task to get it running on a ZCU102 (ZynqMP (Ultrascale+)). The system includes a FreeRTOS-based application running on core 0 and a bare-metal application on core 1.
The Zynq-7000 FSBL starts the FreeRTOS-based application on core 0 which then provides the start address for core 1's application to CPU1STARTADR and call sev to start core 1 running.
I have not found any information about doing something similar on ZynqMP (there are examples of running Linux on the four A53 cores and a separate binary on the R5s).
The boot file creation for ZynqMP includes a "Destination Device" and "Destination CPU" and the FSBL seems to start both (all?) cores. Is this true? Then I need to provide the synchronization between cores 0 and 1 to ensure the application on core 1 does not try to utilize resources before core 0 has initialized things?
Can anyone point to an example similar to this?
Thanks!
.Tim
Thank you @denist for the information and suggestions.
I am moving ahead with an implementation to that allows the two processors to synchronize after power up before continuing processing.
I suggest you take a look at UG1186.
Unfortunately the closest official solution to match your system would be:
FreeRTOS on R5 and Linux on A53.
We don't have FreeRTOS/standalone both on A53.
I doubt you want to use an Hypervisor .... https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842530/XEN+Hypervisor
