SDK 2018.2 - Mini U-Boot not found during QSPI programming
I am using latest SDK 2018.2. When I try to program QSPI Flash using Xilinx Program Flash tool I am getting this error:
Can't find a source file at "/proj/chipscope/xicom_sys/jenkins_clients/xcordevl108/workspace/mini_uboot/mini_uboot_rel/git_mini_uboot/arch/arm/lib/vectors.S"
Boot mode is QSPI. When I switch it to the JTAG boot mode, the tool hangs after print: "Initialization done, programming the memory".
I didn't have any problems with this tool in SDK 2017.2.
What is the solution of this issue?
Nenad
The problem was on my side. I forgot I needed to select System Edition during the SDK installation because I have license only for that Edition. Now the issue is gone. I can successfully program to and boot from QSPI.
