Observer nrubeli
Secure Key Driver - Key String to Hex conversion fails
Dear Community
I am trying to load the hash of a RSA PPK into the PS eFUSE. I followed the document XAPP1175 and was able to calculate the hash, modify xilskey_efuse_example.c, xilskey_input.h and to build the secure key driver.
I generated a bootimage containing the fsbl and the secure key driver elf file. I copied it onto my SD Card and I am able to boot it. But after the FSBL Handoff i get the following error:
PS Data Initialization failed.
I started to debug the xilskey_efuse_example.c file and realized the following:
- My key does get validated successfully (correct length and characters)
- It fails to convert the string to the Hex buffer
To create the hex buffer following function is used:
PsStatus = XilSKey_Efuse_ConvertStringToHexBE(
					XSK_EFUSEPS_RSA_KEY_HASH_VALUE,
					&(PsInstancePtr->RsaKeyHashValue[0]), 64);
if(PsStatus != XST_SUCCESS) {
      return PsStatus;
In this function it fails at this particular part:
u32 XilSKey_Efuse_ConvertStringToHexBE(const char * Str, u8 * Buf, u32 Len)
if(Len != (strlen(Str)*4U)) { Status=(u32)XSK_EFUSEPS_ERROR_PARAMETER_NULL; goto END; }
Len is a hardcoded 64 and Str is the ppk hash (string containing 64 chars)...
So it actually executes:
if(64 != (64*4U)) {
		goto END;
This obviously fails... why is there a multiplication *4U? I mean this code is provided by Xilinx and not by me.. I am pretty confused now. Is it save to delete this multiplication or should the size of my rsa ppk hash somehow be smaller? (I generated this hash by running the bootgen -image gen_hash_ppk.bif -efuseppkbits hash_ppk.txt command) it yielded a txt document containing 64 chars.
I would really appreciate your help on this one.. thanks!
Observer nrubeli
Re: Secure Key Driver - Key String to Hex conversion fails
Instead of the hardcoded 64, 256 should get passed. This represents the length of the ppk hash in bits.
Observer nrubeli
