spujuri
Unable to boot from qspi and able to boot from Micro SD card using same BIN file
We are using Trendz TE0808 SOM for booting from QSPI. I generated a BIN file in Xilinx SDK 2019.1 and used that BIN file for Flash Programming.
1. When BIN File is used in Micro SD card and booting mode for Micro SD is set.It is booting properly.
2. Where as when I am using the same BIN file to flash in and boot from QSPI. Booting is not happening and also tried with MCS file but didn't find any success.
Attached UART log in QSPI boot mode failure case after enabling FSBL debug print.
abommera
Hi @spujuri,
>> Are you using 2019.1 FSBL? From QSPI boot log, FSBL is generated for 2018.1. Have you programmed QSPI flash successfully?
>> Can you provide a screenshot of your QSPI hardware configuration (you can find this in Vivado PCW) and flash programming log?
Thanks & Regards
Anil B
