Unexpected error while launching program: Error while running ps7_init method. Cannot write to target Cannot access JTAG-DP: invalid ACK value (0x00, expected=0x02) Error Address = 0xf8000778
HI,
not able to debug the application code for arm, but able to program fpga from "program FPGA " option in xilinix tools, why is this problem occurring. Previously my board used to work properly.
I am using zed board.
Please help me to sort out this issue. I am struggling from 7 days, please help me.....................
Hi nagavenkat,
Which SDK version are you using?
Are you using System Debugger or GDB?
Andres
Hi Sir,
SDK version is 2014.2
I am using GDB.
Hi nagavenkat,
Can you try with System Debugger and report the output?
Andres
Hi Sir,
Debugging through  System debugger.
error is shown in the image attached
Hi nagavenkat,
Is your JTAG connection reliable? Are you able to target the board in Vivado Hardware Manager?
Andres
Hi Sir,
I am able to connect the target board in Vivado Hardware Manager & impact.
Please find the attached images.
