Zynq 7000 U-boot issue
I'm using Zynq XQ7Z030-1RB484Q_1. As a QSPI flash I'm using S25FL512SAGMFI011.
I'm able to program my Zynq using .bit file but not able to dump .mcs and .elf. I have followed 20K pull-up registets for QSPI mode configuration. My configuration is MIO2-0, MIO3-0, MIO4-0, MIO5-1, MIO6-0, MIO7-0, MIO8-0.
The power sequence for my card is shown attached here by. As well as PS_POR_B and PS_SRST also attached.
Now I connected my customise board using JTAG to Vivado/SDK 2018.2. I tried to load .mcs and .elf file using SDK but it is showing UBoot error.
What to do to resolve this?
Re: Zynq 7000 U-boot issue
Hi @mtalati.18
Are you able to see the processor status using JTAG? May I know the error you are facing? console logs?
Best Regards
Kranthi
Hi @mtalati.18 ,
Could you please refer AR65240 to refer further on Power on sequence for Zynq-7000 platform.
Best Regards
Kranthi
Through JTAG, we are able to detect the processor. I have posted an image of the console.
Please refer the AR suggested for power sequence. It is observed from your images that they POR_B and PS reset signals are not clean. Could you please check once?
Best Regards
Kranthi
