how to boot from emmc on zu3(customer board)
hello, I have booted from sd(SDIO1) successfully, now ,I wanna to boot from emmc(SDIO0).
I have partitioned mmcblk0 to mmcblk0p1 & mmcblk0p2, and copied BOOT.BIN & image.ub to mmcblk0p1,tar rootfs.tar.gz to mmcblk0p2  as ug1137:
But, it cant work when I change boot mode to 0x6.
This is the mount when boots from SD(SDIO1):
/dev/root on / type ext4 (rw,relatime,data=ordered)
devtmpfs on /dev type devtmpfs (rw,relatime,size=892980k,nr_inodes=223245,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /var/volatile type tmpfs (rw,relatime)
/dev/mmcblk0p1 on /media/card type vfat (rw,sync,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/mmcblk1p1 on /run/media/mmcblk1p1 type vfat (rw,relatime,gid=6,fmask=0007,dmask=0007,allow_utime=0020,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/mmcblk0p2 on /run/media/mmcblk0p2 type ext4 (rw,relatime,data=ordered)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
Disk /dev/mmcblk0: 7650 MB, 7650410496 bytes
4 heads, 16 sectors/track, 233472 cylinders
Units = cylinders of 64 * 512 = 32768 bytes
        Device Boot      Start         End      Blocks  Id System
/dev/mmcblk0p1               1       15626      500024  83 Linux
/dev/mmcblk0p2           15627      233472     6971072  83 Linux
Disk /dev/mmcblk0boot1: 2 MB, 2097152 bytes
4 heads, 16 sectors/track, 64 cylinders
Disk /dev/mmcblk0boot1 doesn't contain a valid partition table
Disk /dev/mmcblk0boot0: 2 MB, 2097152 bytes
Disk /dev/mmcblk0boot0 doesn't contain a valid partition table
Disk /dev/mmcblk1: 31.9 GB, 31914983424 bytes
4 heads, 16 sectors/track, 973968 cylinders
/dev/mmcblk1p1             129       32896     1048576   b Win95 FAT32
Partition 1 does not end on cylinder boundary
/dev/mmcblk1p2           32897      973952    30113792  83 Linux
Partition 2 does not end on cylinder boundary
 so, what should I do next ? How to boot from emmc?
回复: how to boot from emmc on zu3(customer board)
If you need, you can try:
1. try other SD cards when boots from SD card.
2. confirm the voltage of emmc and device tree.
now it boots, but with some errors!!!
U-Boot 2018.01 (Apr 29 2019 - 16:00:58 +0800) Xilinx ZynqMP ZCU102 rev1.0
DRAM:  2 GiB
EL Level:	EL2
Chip ID:	zu3eg
MMC:   sdhci@ff160000: 0 (eMMC), sdhci@ff170000: 1
*** Warning - bad CRC, using default environment
In:    serial@ff010000
Out:   serial@ff010000
Err:   serial@ff010000
Model: ZynqMP ZCU100 RevC
Board: Xilinx ZynqMP
Bootmode: EMMC_MODE
Net:   ZYNQ GEM: ff0e0000, phyaddr ffffffff, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for petalinux
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete......
Hit any key to stop autoboot:  0
sdhci_send_command: MMC: 1 busy timeout increasing to: 200 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 400 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 800 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 1600 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 3200 ms.
sdhci_send_command: MMC: 1 busy timeout.
mmc_init: -70, time 7439
** Bad device mmc 1 **
Device: sdhci@ff160000
Manufacturer ID: 13
OEM: 14e
Tran Speed: 52000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
Bus Width: 4-bit
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 7.1 GiB WRREL
Boot Capacity: 2 MiB ENH
RPMB Capacity: 4 MiB ENH
sdhci_set_clock: Timeout to wait cmd & data inhibit
mmc_init: -70, time 3254
ZynqMP>
I have solved it.
COuld you please share the solution ? :)
Cheers,
Trigger
