split jtag : NO operation is possible with arm dap
When we are trying to build the sample UART application with the ZCU102 board, we are getting the error as described in the following URL: https://www.xilinx.com/support/answers/58053.html
We tried the solution provided in Xilinx website but its not working, so please have look at the URL to understand the problem.
We are getting the ERROR message has split jtag : NO operation is possible with arm dap while trying to build the program, even though we are running in Jtag mode.
simon
Hi jharaves@asu.edu
Interim Fix mentioned in AR#58053 is working or not?
Simon
Simon
Hi simon,
I tried but it is not working.
123mutt123
I have this same problem bringing up the zc706 board. I am running the zc706_bist.bat. The PL from ready_for_download correctly installs the bit as follows
****** Xilinx Microprocessor Debugger (XMD) Engine
****** XMD v2015.4 (64-bit)
  **** SW Build 1412921 on Wed Nov 18 09:43:45 MST 2015
    ** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved.
Executing user script : download_bit.tcl
Configuring Device 1 (xc7z045) with Bitstream -- system_wrapper.bit
....................10...................20...................30....................40...................50...................60..
..................70...................80...................90....................Successfully downloaded bit file.
JTAG chain configuration
Device   ID Code        IR Length    Part Name
 1       23731093           6        xc7z045
 but the subsequent attempt to configure the bist_app.elf elicits the following error.
Executing user script : download_elf.tcl
Error Executing User Script : download_elf.tcl
Error :: ERROR:
        Could not find a ARM device on the board. Please check if the target is in:
         1. Split JTAG mode - No operations are possible with ARM DAP
         2. Non Jtag bootmode - Bootrom may need time to enable DAP. Please try again
Physically the diligent jtag cable is connected to windows machine and the USB is connected to a separate Linux machine. Nothing appears on the serial port so I wonder whether the arm device is correctly initialising?
Can anyone help?
thanks
Matt
denist
There's no ARM DAP in the targets which means the bootROM didn't complete execution or the JTAG chain is split (it's one of the boot mode pins). On a  ZCU106 I would suggest to double check the boot modes and be sure you are in JTAG with cascade configuration.
