ratin
u-boot load issue in secure mode (SD boot mode)
Hi,  I am working with a ZC706 eval board, I enabled AES encryption (BBRAM) and RSA PSK/SSK (eFuse) and created boot.bin with encryption enabled. If I use my own bare metal apps to test, I can get past all the secure boot processes and my app runs properly. But if I load u-boot.img + linux/ramdisk image, boot fails throwing the error INVALID_LOAD_ADDRESS_FAIL (partition 2 is u-boot.img)
================== BEGIN =========================================
Xilinx First Stage Boot Loader
<SNIP>
PCAP MCTRL 0xF8007080: 0x34800100
DMA Done !
FPGA Done !
In FsblHookAfterBitstreamDload function
Partition Number: 2
Header Dump
Image Word Len: 0x0001DE0B
Data Word Len: 0x0001DD4C
Partition Word Len:0x0001DFC0
Load Addr: 0x00000000
Exec Addr: 0x00000000
Partition Start: 0x0033D400
Partition Attr: 0x00008010
Partition Checksum Offset: 0x00000000
Section Count: 0x00000001
Checksum: 0xFF905C67
Application
Encrypted
RSA Signed
FSBL Status = 0xA00F
This Boot Mode 0x5 Doesn't Support Fallback
In FsblHookFallback function
================== END ============================
The info on u-boot.img:
u-boot.img: u-boot legacy uImage, U-Boot 2017.01 for zynq board, Firmware/ARM, Firmware Image (Not compressed), 488688 bytes, Thu Mar 25 22:12:39 2021, Load Address: 0x04000000, Entry Point: 0x04000000, Header CRC: 0xD99DD5F7, Data CRC: 0x674D1203
I compiled u-boot from uboot-mathworks_zynq_R20.2.0 distro
My bif file:
//arch = zynq; split = false; format = BIN
the_ROM_image:
[aeskeyfile]output.nky
[ppkfile] /home/ratin/work/rsa/ppkfile.pub
[pskfile] /home/ratin/work/rsa/pskfile.pem
[spkfile] /home/ratin/work/rsa/spkfile.pub
[sskfile] /home/ratin/work/rsa/sskfile.pem
[bootloader, encryption = aes, authentication=rsa]ratin_fsbl_debug_enabled.elf
[encryption = aes, authentication=rsa, offset = 0x40000]system_wrapper.bit
[encryption = aes, authentication=rsa, offset = 0xCF5000]../u-boot.img
[encryption = aes, authentication=rsa, offset = 0xd80000]../uImage
[encryption = aes, authentication=rsa, offset = 0x11E0580]../uramdisk.image.gz
[encryption = aes, authentication=rsa, offset = 0x3a00000]devicetree.dtb
Keeping everything else intact, just changing the u-boot.img to my own bare-metal app makes it to work.
Any idea why the load/exec  addr reported as 0x000000 for the u-boot.img?
Ratin
ibaie
Hi @ratin
You BIF file does not seem to be appropriate for me, I mean you are loading a bunch of binary blobs but you do not specify where to load any of them, so not surprisingly the FSBL seems to be using address 0x0 for all of them. As documented in UG1283, you should use the load attribute to provide the load address of the different blobs.
Ibai
ratin
Hi Ibalie,
 Thanks a lot for your reply - I modified the bif file to add DDR offsets, now it goes thru loading them in the DDR offsets but handoff still 0x0 - How can I force it to be where u-boot.img is loaded (0xD000000)?
Log
the_ROM_image:
[bootloader, encryption = aes, authentication=rsa, load=0x0]ratin_fsbl_debug_enabled.elf
[encryption = aes, authentication=rsa, load=0x100000, offset = 0x40000]system_wrapper.not
[encryption = aes, authentication=rsa, load=0xD00000, offset = 0xCF5000]../u-boot.bin
[encryption = aes, authentication=rsa, load=0xE00000, offset = 0xd80000]../uImage
[encryption = aes, authentication=rsa, load=0x2000000, offset = 0x11E0580]../uramdisk.image.gz
[encryption = aes, authentication=rsa, load=0x6000000, offset = 0x3a00000]devicetree.dtb
FSBL is running from internal ram so I didn't provide a load= attribute for it (am I supposed to?).
Release 2018.2 Mar 25 2021-14:08:57
Devcfg driver initialized
Silicon Version 3.1
Boot mode is SD
SD: rc= 0
SD Init Done
Flash Base Address: 0xE0100000
Reboot status register: 0x60400000
Multiboot Register: 0x0000C000
Image Start Address: 0x00000000
Partition Header Offset:0x00000C80
Partition Count: 6
RSA enabled for Chip
Partition Number: 1
Header Dump
Image Word Len: 0x0032D20B
Data Word Len: 0x0032D14B
Partition Word Len:0x0032D3C0
Load Addr: 0x00100000
Partition Start: 0x00010000
Partition Attr: 0x00008012
Checksum: 0xFF223476
Application
Encrypted
RSA Signed
Authentication Done
PCAP:StatusReg = 0x40000A30
PCAP:device ready
PCAP:Clear done
PCAP register dump:
PCAP CTRL 0xF8007000: 0x4E80EE80
PCAP LOCK 0xF8007004: 0x00000012
PCAP CONFIG 0xF8007008: 0x00000508
PCAP ISR 0xF800700C: 0x00030000
PCAP IMR 0xF8007010: 0xFFFFFFFF
PCAP STATUS 0xF8007014: 0x0066FA30
PCAP DMA SRC ADDR 0xF8007018: 0x00100001
PCAP DMA DEST ADDR 0xF800701C: 0x00100001
PCAP DMA SRC LEN 0xF8007020: 0x0032D20B
PCAP DMA DEST LEN 0xF8007024: 0x0032D14B
PCAP ROM SHADOW CTRL 0xF8007028: 0xFFFFFFFF
PCAP MBOOT 0xF800702C: 0x0000C000
PCAP SW ID 0xF8007030: 0x00000000
PCAP UNLOCK 0xF8007034: 0x757BDF0D
DMA Done !
Partition Number: 2
Header Dump
Image Word Len: 0x0001DDFB
Data Word Len: 0x0001DD3C
Partition Word Len:0x0001DFB0
Load Addr: 0x00D00000
Checksum: 0xFEC05CA7
Application
Encrypted
RSA Signed
Authentication Done
PCAP:device ready
PCAP:Clear done
PCAP register dump:
PCAP ISR 0xF800700C: 0x00033000
PCAP STATUS 0xF8007014: 0x50000A30
PCAP DMA SRC ADDR 0xF8007018: 0x00D00001
PCAP DMA DEST ADDR 0xF800701C: 0x00D00001
PCAP DMA SRC LEN 0xF8007020: 0x0001DDFB
PCAP DMA DEST LEN 0xF8007024: 0x0001DD3C
DMA Done !
Partition Number: 3
Header Dump
Image Word Len: 0x00113FAB
Data Word Len: 0x00113EE8
Partition Word Len:0x00114160
Load Addr: 0x00E00000
Partition Start: 0x00360000
Checksum: 0xFE6E7DDB
Application
Encrypted
RSA Signed
Authentication Done
PCAP:device ready
PCAP:Clear done
PCAP register dump:
PCAP STATUS 0xF8007014: 0x0046CA30
PCAP DMA SRC ADDR 0xF8007018: 0x00E00001
PCAP DMA DEST ADDR 0xF800701C: 0x00E00001
PCAP DMA SRC LEN 0xF8007020: 0x00113FAB
PCAP DMA DEST LEN 0xF8007024: 0x00113EE8
DMA Done !
Partition Number: 4
Header Dump
Image Word Len: 0x009B11DB
Data Word Len: 0x009B1117
Partition Word Len:0x009B1390
Load Addr: 0x02000000
Partition Start: 0x00478160
Partition Attr: 0x00008011
Checksum: 0xFB04324B
Application
Encrypted
RSA Signed
Authentication Done
PCAP:device ready
PCAP:Clear done
PCAP register dump:
PCAP STATUS 0xF8007014: 0x00A6FA30
PCAP DMA SRC ADDR 0xF8007018: 0x02000001
PCAP DMA DEST ADDR 0xF800701C: 0x02000001
PCAP DMA SRC LEN 0xF8007020: 0x009B11DB
PCAP DMA DEST LEN 0xF8007024: 0x009B1117
DMA Done !
Partition Number: 5
Header Dump
Image Word Len: 0x0000135B
Data Word Len: 0x00001299
Partition Word Len:0x00001510
Load Addr: 0x06000000
Partition Start: 0x00E80000
Checksum: 0xF82F2EF8
Application
Encrypted
RSA Signed
Authentication Done
PCAP:device ready
PCAP:Clear done
PCAP register dump:
PCAP DMA SRC ADDR 0xF8007018: 0x06000001
PCAP DMA DEST ADDR 0xF800701C: 0x06000001
PCAP DMA SRC LEN 0xF8007020: 0x0000135B
PCAP DMA DEST LEN 0xF8007024: 0x00001299
DMA Done !
Handoff Address: 0x00000000
In FsblHookBeforeHandoff function
No Execution Address JTAG handoff
ratin
It would be interesting to know how the handoff process work. I noticed if I use an older u-boot.elf file, fsbl spits out its exec address properly (0x4000000). So after I modified to also load uboot into 0x4000000, handoff succeeds now but then its completely silent, looks like linux is not booting. With the new u-boot.img file, the same result if I hardcode the handoff address in FSBL. So with the handoff succeeding, what could be the issue thats preventing linux to run? Is there a boot.bin from Xilinx I could try for SD card boot?
<snip>
DMA Done !
Handoff Address: 0x04000000
SUCCESSFUL_HANDOFF
FSBL Status = 0x1
here is u-boot partition info printed:
Partition Number: 2
Header Dump
Image Word Len: 0x00022E8B
Data Word Len: 0x00022DC4
Partition Word Len:0x00023040
Load Addr: 0x04000000
Exec Addr: 0x04000000
Checksum: 0xF78F1A6F
Application
Encrypted
RSA Signed
Authentication Done
PCAP:device ready
ibaie
Hi @ratin
If you take a look to the Bootgen documentation you will notice that the tool does not read header information from img files so is treated as binary blob. Binary blobs does not have any information about the load address or entry point so there is no way for Bootgen to provide that information to FSBL, that's why you need to specify the load address and execution address if you are expecting to handoff to the partition (see load and startup attributes).
Once FSBL handoffs to U-Boot, you should be able to see first U-Boot serial printouts not Linux, which I guess is not happening from your previous comments. If that is not working probably the issue is in your U-Boot image. How did you build? Can you provide information about the steps you have followed?
For Xilinx evaluation boards you can find pre-built images or you can use provided Petalinux BSPs to build or us pre-built individual components.
Ibai
ratin
I am not able to reply - will try again after logging out
ratin
Hi Ibai,
Thanks for your reply. Yes, no u-boot prompt, the u-boot was build from Mathworks buildroot as part of the linux kernel build, they provide a few python scripts. Normal location for it is specified in buildroot/configs/zynq_zc706_defconfig is u-boot-xlnx.git from github
which has latest changes, however the the build version located in out/build is uboot-mathworks_zynq_R20.2.0 (probably locked into this rev since buildroot itself was from that version)
in either case, this same u-boot image works its put into the SD card as is along with script generated SD card image and doesnt work if I wrap it in boot.bin as part of bootgen. I dont understand the difference yet, the SD card image has a flat file system with a smaller boot.bin, no FSBL (unless it gets put into the boot.bin), u-boot.img, linux kernel, system.bit and the dtb files
Ratin
ratin
After some digging, I think I need to disable SPL from u-boot build
ratin
I am now getting DATA_ABORT_HANDLER - is this because the dtb file doesnt match the hardware, or something like that? What basic config do I need to enable in uboot defconfig for zc706 that will allow me to use the UART? I think I only have axi-uartlite enabled in my board's block design, the dtb has the relevant entry but not sure what u-boot config items I have to enable.
SUCCESSFUL_HANDOFF
FSBL Status = 0x1
DATA_ABORT_HANDLER
FSBL Status = 0xA304
