xilinx platform-cable usb stopped working
I'm new to zynq, i have ultra96 board and xilinx platform-cable usb (DLC9LPPMC)
few month ago, i installed requirements and finally success to program the board using JTAG! but always i had problem to start programing with xilinx platform-cable, sometimes it works correctly and sometimes i should un-connect and connect the jtag or turn off and on the board or ... to start programing (in fact i dont know what i'm doing!!!)
few days ago, i wanted to program the my board, but failed! i tried above things but i couldn't program the board
I'm sure os identify the xilinx platform (dmesg information in terminal)
and this is the error of SDK image :
im using ubunu 16.04, vivado and sdk 2018.3
this is also XSCT response to connect --> jtag ta :  1 Platform Cable USB 00000000000000 (error DR shift output all ones)
finally this my xilinx platform image :
for more information : this section maybe useless but as i'm new to zynq, maybe i store data in wrong place
im using axi-dma and write data in 0x0000 address of DDR, i think after this project i cant program my board anyway
How can I fix this problem?
thanks
That is not a Xilinx supported programmer,
you had better talk to the supplier for technical support,
these are about the lowest cost supported programmers
https://store.digilentinc.com/jtag-hs3-programming-cable/
