lkdi15
zcu102 wathdog timer
I am using cadence wdt
What is the maximum timeout that can be used for watchdod0 on the zcu102 board ?
ibaie
Hi @lkdi15
The maximum counter value that you can program in the WDT is 0xFFFFF. Now, depending on the clock used to feed SWDT and the prescaler used, you can calculate the maximum time.
Ibai
