mushihao
zcu106 hello world ARM hanging at the beginning
I am using Vivado 2018.3 SDK and running hello world on both a53 and r5. I found the program hanging at the very begining, falling into some exception handler. Attached A53 screenshot. Similar thing happened when I used r5 to run hello world.
I can boot linux with SD card in the same board. Any suggestion on what the issue could be?
Hao
florentw
HI @mushihao
Could you try running the fsbl before running the application. And when you run the application, disable psu_init.
I think your issue is related to AR#71961
Florent
florentw
HI @mushihao
Florent
mushihao
Hi Florent,
I am able to see "hello world" now as your suggestion. I ran fsbl first and then the app. I disabled pmu_init in both steps. Thank you for your help!
Hao
jbonanno1
Another suggestion is to check the Zynq memory setup and make sure that the settings are correct. There are several threads on this, as the ZCU106 was shipped with a different Micron memory module. Running FSBL is fine, but you should be able to run out of SDK.
The posts are here:
https://www.xilinx.com/support/answers/71961.html
https://www.xilinx.com/support/answers/72210.html
https://www.xilinx.com/support/answers/72113.html
