hezi
AIE opcode list
Where can I find a list and explanations of opcodes for AIE in order to debug the microcode?
Tags (3)
florentw
HI @hezi
Unfortunately this level of detail is not exposed to users.
Florent
hezi
So what is the purpose of assembler view if we can't use it?
florentw
HI @hezi
You can at least see where there are No Operation (NOP)  and check the corresponding line in your C code. This can still give you guidelines how used the pipeline is
Florent
