hsfzlt
AIEngine on ACAP can not be run by Vitis (Lack of XRT for 2020.3)
Dear officer,
I recently have an ACAP (VCK190) set up in the lab. I have successfully run the HelloWorld application in Windows version Vitis. Then I want to try the AIEngine example based on the 2020.3 base platform which required Linux OS but I found out that XRT for 2020.3 is not available for Linux ( I am using Ubuntu 18.04.2 version which should be fine). Is there any solution to run the example for AIEngine? Thanks!
Tags (3)
florentw
HI @hsfzlt
In 2020.3 (as in 2020.2) you do not need to install XRT separately as it was needed in 2020.1. XRT for the embedded acceleration platforms is already in Vitis installation.
Let me know if you are facing any error
Florent
