02-16-2021 12:52 PM
Let's say I have an AIE kernel with an asynchronous window of size 9 * sizeof(int16) = 18 bytes, reading data for 5 iterations from a PL data mover such that the total amount of data read is 90 bytes. The smallest supported ap_axis is 32 bits for an HLS kernel connected to an AIE graph, so in 32-bit or 4-byte increments, the PL kernel will feed the AIE tile 92 bytes. Is there any way to consume and discard those extra 2 bytes in my AIE kernel such that the next window_acquire() will give me with a full 18 byte window containing 9 * int16 new values?
Basically, I am looking for:
void my_kernel(input_window<int16>* in)
for (i = 0; i < 5; ++i)
window_acquire(in); // 18 bytes ready
// Process "in" using window_readincr() 9 times
window_release(in);
// Now we need to deal with 2 extra bytes, and then we want
// the next window_acquire() to give us a full 18 byte window
// of new data, as if those previous 2 bytes never existed.
02-17-2021 01:19 AM
HI @e_ensafi
No I do not believe this is possible with the current architecture. The DMA will completely fill the memory buffer with the size it was set.
The options that you have:
02-17-2021 01:19 AM
HI @e_ensafi
