ami.kum
Binary Counter v12.0 verilog file
Hi!
I am trying to use DSP48E2 block to implement a 8 bit counter.
I came across Binary Counter V12.0 in the IP library. But it looks like the RTL and simulation is only available in VHDL.
I was wondering if this IP is available in verilog. I am more concerned with simulation aspect as I don't have mixed language simulator.
-AK
vkanchan
Hi @ami.kum
The IP is only available in VHDL. Which simulator are you using ? If you have the Vivado simulator,it is a Mixed language simulator and it should work on it.
ami.kum
I am using ModelSim. I will switch to Vivado Simulator.
dpaul24
@ami.kum,
It is also possible to do mixed language simu using ModelSim. I suspect you have some Modelsim setting incorrect.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
ami.kum
Yes. It requires a mixed language simulation license. I only have license version which support only Verilog.
