Newbie djberry55
Black Box Block RAM Allocation
I am using Simulink HDL coder to generate HDL code that I then use the System Generator Black Box block to synthesize my HDL code.  My Simulink model has several lookup tables and the process I am following seems to place the lookup-table in distributed RAM instead of Block RAM.  I need quite a few lookup tables and if I add too many, I run out of distributed RAM, but would have sufficient BRAM available if they were allocated there.  I am not sure how to ensure my lookup-tables are implemented in BRAM.  Any assistance would be appreciated.
回复: Black Box Block RAM Allocation
This is really a synthesis question, you might need to add a constraint like “use block ram", check the synthesis user guide.
