orangepeace
Can hardware co-sim support my own board?
Hi all,
  Can hardware co-sim support my own board? How to configurate it? Can you give me an example? I cannot find it in the application note.
Best Regards.
ywu
Yes. Take a look at the blog below to see if it helps:
SysGen: Create New HWCOSIM Target with NMM Ports
@orangepeace wrote:
Hi all,
Best Regards.
Cheers,
Jim
orangepeace
Hi Jim,
   The link that you give cannot work. Pls check it.
Best Regards.
sofiene
You find it attached,
___
Sofiene
eilert
the link is OK, even with Script- and AD-Blockers.
If your browser can't handle it, here's the bare URL:
http://myfpgablog.blogspot.com/2009/12/sysgen-create-new-hwcosim-target-with.html
Have a nice synthesis
  Eilert
ywu
It could be that your internet service provider is blocking the Google Blogger site. Anyway, I printed it as a PDF and attached it below.
@orangepeace wrote:
Hi Jim,
Best Regards.
Cheers,
Jim
