R_Vijayakumar
Can we register PCOUT of DSP48E2 before connecting to next DSP48E2's PCIN?
I am experimenting with DSP48E2 to create 3 input adder(48bits). I wanted to achieve this function with one DSP48E2 slice.  I have configured  ALUMODE = "0000" and OPMODE = "110010011" => (A:B)+C+PCIN.
In my design, 1st DSP48E2's PCOUT will be connected to PCIN of 2nd DSP48E2 slice via external register to match the clock latency of A,B and C ports.
avrumw
Expert
Expert
Can I connect a register output to PCIN
No. The only legal connection to the PCIN is the PCOUT of the DSP48 directly below it - there are no other legal connections. (Similarly the PCOUT can only connect to the PCIN of the DSP48 above it - there are no other connections).
You would have to exit on the P output, do what you want in the fabric and then enter back in on one of the non-cascade inputs (C, or A:B)
Avrum
vkanchan
HI , The 'P' register can be used to register the PCOUT. Refer Fig 2-1 in UG579
R_Vijayakumar
Thanks a lot vkanchan for your reply. It helps during the DSP cascading. I have one more question related to PCIN.
As I want to perform 3 input(48bits) adder using one DSP slice. Can I connect a register output to PCIN?
avrumw
Expert
Expert
Avrum
R_Vijayakumar
Thanks Avrumw for your clarification.
