Observer kbkien
DDS questions.
I used coregen to generate a DDS as below parameters:
f_clk = 250 MHz
f_output = 62.5 MHz (= 250/4)
B_n = 18 bits
phase_increment = 65536
To ensure I have a correct sine wave frequency, I have performed a simulation using Modelsim. My understanding is, a full cycle sine wave (output) should be completed within 4 clock cycles for such system. However, the output of the sine wave from my simulation used 408 clock cycles for a complete sine wave. I have read the data sheet twice and can't really understanfd why. I would be greatly appreciate if someone can help me. Thank you very much.
Re: DDS questions.
The clock is too fast. Change the period to something like 10ns and run it again. It would help if you can attach your complete project with the dds core in it. Also change the radix of dds output to signed number.
@kbkien wrote:
This is my testbench. The funny part is the phase_tdata is 0.
module dds_tb;
reg                 clk          = 0;
reg                 conf_in_tvld = 1;
wire                data_out_tvld;
wire                phase_out_tvld;
reg         [23:0]  conf_in_tdata = {6'd0,18'd65536};
wire        [15:0]  data_out_tdata;
wire        [23:0]  phase_out_tdata;
wire signed [15:0]  sine;
// Generate clock
always #1 clk = !clk;
// DUT
dds DUT(
  .aclk                 (clk),
  .s_axis_config_tvalid (conf_in_tvld),
  .m_axis_data_tvalid   (data_out_tvld),
  .m_axis_phase_tvalid  (phase_out_tvld),
  .s_axis_config_tdata  (conf_in_tdata),
  .m_axis_data_tdata    (data_out_tdata),
  .m_axis_phase_tdata   (phase_out_tdata)
assign sine = $signed(data_out_tdata);
endmodule
Cheers,
Jim
Scholar austin
Re: DDS questions.
k,
So, you have exactly 4 samples in this:  since on each clock you add 1/4 cycle (to get a divide by 4 of 250 MHz).  This is not a good sign wave (0, +1, 0, -1, ....).  If this is all you want, you could do it with a counter.
Given those numbers, I see no way that you have 408 clock cycles for anything at all:  in four clocks you are back to 0.
Austin Lesea
Principal Engineer
Xilinx San Jose
Observer kbkien
Re: DDS questions.
Thanks for your reply.I thought f_clk > 2*f_output to follow the nyquist sampling theorem?
I intend to have a dds which can generate sine wave with different frequencies and 250/4 MHz is one of them.
Scholar austin
Re: DDS questions.
k,
Well, it is true that four sample satisfies the Nyquist Sampling Rate requirement, but it is not nearly fast enough for any fidelity requirements (harmonic distortion, etc.).
If you require a sine wave, then you need perhaps 1024 points, minimum for a ful cycle, or 256 points for the quarter  cycle (is sufficient storage).  That means the highesdt frequency sine wave you may generate is ~Fclk/1000.
An alternative is to use the MSB of the phase accumulator as the output directly to a PLL.  The PLL is then set to oscillate in a narrow range about the Fout of the phase accumulator.  When locked, the VCO is then used directly (assuming a sine wave voltage controlled oscillator).  I doubt seriously you get a sine wave from 0 to 63 MHz by any means that doesn't involve switching sources, filters, methods, etc.
There is a reason why good bench test equipment oscillators cost so much money....
Austin Lesea
Principal Engineer
Xilinx San Jose
Professor
Professor
Re: DDS questions.
Did you use a fixed phase increment when you generated the core?  Or did you
generate the core with a phase increment input port and supply the phase increment
in your test bench?  If you really have an 18-bit accumulator, then you'd need a phase
increment of about 643 instead of 65536 to generate a sine wave in 408 clocks.
If you used a fixed phase increment, I'd go back through the core setup again
and make sure it has the correct values for input and output frequency and accumulator
bits.
-- Gabor
-- Gabor
Observer kbkien
Re: DDS questions.
Thanks for the replies. It is a programmable phase increment. I regenerated the core again and it showed the same results.
Any suggestions?
Re: DDS questions.
Please post the waveform with all signals to/from the DDS core. Sometimes the waveform can be deceiving when it comes to the frequency components in the signal.
Any suggestions?
Cheers,
Jim
Observer kbkien
Re: DDS questions.
module dds_tb;
reg                 clk          = 0;
wire                data_out_tvld;
// Generate clock
// DUT
dds DUT(
  .aclk                 (clk),
endmodule
Observer kbkien
Re: DDS questions.
In addition, there isn't negative part of the wave. I guess coregen only creates half sine wave.
Re: DDS questions.
module dds_tb;
reg                 clk          = 0;
wire                data_out_tvld;
// Generate clock
// DUT
dds DUT(
  .aclk                 (clk),
endmodule
Cheers,
Jim
Observer kbkien
Re: DDS questions.
You are absolutely right! The clock is too fast. Thank you so much for your help.
