DEMUX block in Xilinx System generator is not available?
I used mux block in encoder section and for the o/p i have to use "demux"  block at to the decoder side.
Xilinx is not providing demux block? How can i solve the problem?
I want to design demux block with 32 outputs.
Help me.. Thanks in adv
Hemanth
Hemanth
vsrunga
To keep sim[ple, as you are using 14.2, please check in  "Simulink Blocks Supported by System Generator" section of UG638 released for 14.2, if you see Demux in that list than you can staright away use it, else upgrade ISE to latest version as Matlab R2012a is aslo suppoerted for 14.7
Vanitha.
vsrunga
I can see it 14.7 + Matlab R2013a, what tool versions are you using?
but it seems Simulink block, please check this link
http://www.xilinx.com/support/answers/17520.htm
i am using 14.2+ matlab r2012a
Hemanth
u are talking abt these blocks ( Concat, Reinterpret, and Slice blocks)?  these blocks will not work like demux
Hemanth
i need xilinx block.. i already saw the link and those blocks are not useful.
i used mcode block to design a demux. i need 32 outputs for that i need 5 selection lines.   The one i designed also contains selection lines. But in xilinx mux block even for 32 i/p there is only 1 selection line.  How xilinx designed mux block?
Even i need a demux block having 1 section line for n input
Hemanth
vsrunga
Good that you have made Demux using mcode.
The AR says that in older version as Xilinx blockset do not have Demux you can build DEMUX functinality using reinterpret, slice and concat blocks not that those blocks can be used for Demux.
I think your question on Mux select is clarified in this post.
http://forums.xilinx.com/t5/Digital-Signal-Processing-IP-and/Doubt-related-to-Xilinx-System-generator-MUX-block/m-p/401157#M3804
In latest version you can use Simulink Demux block for generating the code as it is supported by Sysgen.
Please refer "Simulink Blocks Supported by System Generator" section of UG638
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/sysgen_ref.pdf
Hope this clarifies
Vanitha
Dear vanitha,
Thanks for your valuble info
U said in older versions demux block is not available. thats fine
But which versions of ISE i have to use for inbuilt Xilinx block?
I am not getting how to build demux functionality (block) using reinterpret, slice and concat blocks.
If u have any demo model then please attach here..
Hemanth
vsrunga
Vanitha.
wow! thank u very much  vanitha..
i referred the doc ug 638.
Hemanth
simulink demux block has no selection line.. how can i connect my o/p to selection line?
Hemanth
markus.offergeld
a way to build the Demux would be to Concat your 5 selection lines then use 32 relational blocks to check if the 5bit selection singal equals the values 0 to 31. Each result is then connected to the enable of a register like below:
Of course with 32 such block combinations and not just 4 like in the picture.
You might maybe also take a look at Time Domain Multiplexing and Demultiplexing blocks
I hope i could help
Regards Markus
balkris
demux is the simulink block supported by sysgen . Demux supports same features as in simulink.
For your customize application i would recommend to create your own library or use vhdl code and import the mux functionality with using blackbox application. You can also write matlab code and use M code block.
Thanks and Regards
Balkrishan
