Down sampling problem in Discrete wavelet transform
Hello everyone
I'm newbie in system generator and I ran into a problem, I'm trying to implement discrete wavelet transform (dwt) so i have a 128*256 image, I need to do down sampling to rows; that is I use the first row, omit the second, use the 3rd etc. how can I do that using system generator?
Thanks in advance
Re: Down sampling problem in Discrete wavelet transform
There is a down sampling block in the System Generator, FIR Compiler can also implement down sampling.
Thanks for replay
sir, that block can not help me because it omit only one pixel in a time,
for example if i put setting 5 in down sample
from every 5 pixel it omit one while i need it to omit first 5 pixel and keep the second 5 pixel and so on
can you suggest to me another block?
Tags (2)
