Error during Netlist Generation
I was trying to generate a netlist from a simple Model in simulink. I can run the simulation (using  sysgen).
When I try to  create a netlist , it throws an error :
*** ERROR ***
Errors occurred during netlist generation.
Error using ==> xlProcBlockElaborateBMM at 19
synopsis file 'C:\<..>\timing\synopsis' not found
So, I tried to create a synopsis folder manually, and then It started throwing following error:
*** ERROR ***
Java exception occurred:
com.xilinx.sysgen.netlist.NetlistInternal: java.io.FileNotFoundException: C:\Kiran\timing\synopsis\synopsis (Access is denied)
    at com.xilinx.sysgen.netlist.XTable.valueOf(Unknown Source)
    at com.xilinx.sysgen.netlist.Block.fromXTable(Unknown Source)
I tried running Matlab as Administrator, but with same outcome. Kindly let me know if I am missing something here:
So, here are the config details :
Matlab version :  Version 7.10       (R2010a)
Xilinx System Generator                               Version 12.2
Kiran
Tags (3)
Re: Error during Netlist Generation
This might be an install problem.
You might try reinstalling the tools.
Also make sure that you select XST as the syntehsis tool.
Chris
Video Design Hub | Embedded SW Support
