thijscraenmehr
Error with MCODE block
This is the MCODE that I'm using:
function angle = CalcAngle(tau)
  c = 340.29;
  Fs = 44100;
  d = 0.02;
angle = cos(((c*tau)/Fs)/d)^(-1);
And this is the error I'm having:
Error("CalcAngle.m"): Syntax error: Encountered "^" at line 5, column 28.
What am I doing wrong? Or am I doing something that is not possible with the MCODE block?
Thanks in advance,
Thijs
thijscraenmehr
Does this maybe have to do anything with the fact that the mcode blocks do not support algorithmic MATLAB functions?
If this is true, how do I get my mfile (which works perfectly) to VHDL?
eilert
Hi Thijs,
your doubts are reasonable.
you should read abourt the restrictions that apply to synthesizable mcode for the system generator.
Just to get an idea of what you are doing:
Everything in system generator works with HDL-compatible fixed point types.
In your code you have defined two values c and d with fractional digits.
So, what type should they be?
   Float/double? Not suported in sysgen!
   Fixed Point?
     If so, unsigned or signed?
           And how many bits?
                And then...how many fractional bits?
Then you have this mathematical operation.
While the multiplications could be done quite easy, the divisions would cause trouble,
not to speak about the high level functions like ^ and cos.
And all of this is required to be done combinatorical?
Remember that you are about to design some real hardware.
It's different from writing some software, with lots of functions in the background all mixed up in a huge memory with lots of time to perform the desired action. (milliseconds are a little eternity for todays CPUs)
Instead you are dealing with thousands of logic elements, all eager to do their job at the same time, and you are the one who needs to define when precisely each elements operation is allowed so their combined action results in something useful.
For MCODE blocks there are special functions available, each representing some element of the xilinx blockset.
These functions begin with a "x" followed by their operations name.  They can help you to perform complex operations inside a MCODE block.  Also, maybe some of your variables need to be declared as "persistent", so they become registers.
Some hint: for cos and other mathematical operations, the CORDIC block can be helpful.
Have a nice synthesis
  Eilert
thijscraenmehr
Hi Eilert,
Thank you for your reply.
I will be working this day to try and make it working :)
I also read something about AccelDSP:
AccelDSP™ synthesis tool is a high-level MATLAB® language based tool for designing DSP blocks for Xilinx FPGAs (http://www.xilinx.com/tools/acceldsp.htm)
Could this be useful in my case? I do have a license for ISE Design Suite 12.1
With kind regards,
Thijs
thijscraenmehr
Hi all,
This is still not working for me, and I don't know what I'm doing wrong here.
I did use the CORDIC blocks and some other blocks to make it easier vor the MCODE block.
I have attached my .mdl file, so if anyone here is able to tell me what I'm doing wrong?
Im a beginner with the Xilinx blockset and programming FPGA's.
Thanks in advance,
Thijs
eilert
the AccelDSP tool is no longer part of the ISE Tools.
I think it has been discontinued after ISE 11.x.
  Eilert
eilert
Hi Thjis,
that's a nice model, but quite useless without the m-files for the mcode blocks.
They are not embedded in the model.
Maybe you could provide them too? :-)
  Eilert
thijscraenmehr
The M-files that I was using for the blocks, is written in text above the blocks.
So for example MCode1 (fastfourrier), it is:
function z = Fastfourrier(x)
z = fft(x)
I'm now using the FFT xilinx block and others, but I'm still having problems with 'abs' and 'conj'
Is it smart to use sqrt(x^2) to get 'abs(x)'?
And how do I get the conjugated part of an array, without the function conj(x)?
Thanks in advance,
Thijs
eilert
my guess was that the codes you wrote above the blocks should serve as some kind of documentation, since high level matlab functions like fft(x) just don't work in an mcode block, so I thought that you already have some self created low level mcode-mfile which is synthesizable.
The same that applies to fft(x) also holds for sqrt(x^2),  abs(x) and conj(x).
abs(x) might look like this in synthesizable m-code:
if x<0 then
  x=(not x) + 1;  % be aware of the data types! This example works only for numbers without fractional parts
end
As you can see, it's the two's complement conversion algorithm.
So if you need to conjugate an array, recreate the formula and do it element for element.
Just for get about all the high level functions you have in matlab. this is hardware sysnthesis, and all the functions you can use are in the xilinx library which is also represented in the xilinx blockset in a graphical way for use with simulink.
  Eilert
