Export block IP core xilinx in simulink
Re: Export block IP core xilinx in simulink
@jackn
The IP in the link is already in Vivado IPI. You don't need to export it from Simulink.
If you want to export Sysgen design to Vivado IPI, please refer to Packaging the Design for Use in Vivado IP Integrator
 (page 105 and onwards) of Sysgen User Guide :
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug897-vivado-sysgen-user.pdf
In simple terms, i develop my system in simulink with SysGen and after i use this system block in IP vivado design?
news?
@jackn
You mentioned "In simple terms, i develop my system in simulink with SysGen and after i use this system block in IP vivado design?", yes. that's correct.
Sorry for the late response, I don't visit forum everyday. if you don't use @ + my user name to reply, I don't get notifications.
