FFT of an image
How to calculate FFT of an image in matlab??
suppose it is a 32x32 image that means it is nothing but 1024 inputs ???
Re: FFT of an image
Please check below links
http://biocomp.cnb.csic.es/~coss/Docencia/ImageProcessing/Tutorial/
http://www.researchgate.net/post/Can_someone_please_provide_me_some_MATLAB_code_for_image_transforms_2D_DFT
http://in.mathworks.com/matlabcentral/answers/41464-fft-of-an-image
http://apps.usd.edu/coglab/schieber/psyc707/pdf/2D-FFT.pdf
Hope they will give you a better start
-Vanitha
Re: FFT of an image
Parallel Algorithm for 2-D FFT
The algorithm consists of following five steps
Step 1:
a). Calculate 1-D FFT by using Xilinx Coregen for 32 point in streaming mode.
b). Verify 1-D FFT for different random signal
C). Verify the FFT result with Matlab function for same input sequence. FFT result should match with Matlab.
Step2:
a) Calculate 1-D IFFT using Xilinx Coregen for 32 Point in Streaming mode
C). Verify the IFFT result with Matlab function for same input sequence. FFT result should match with Matlab.
Thanks and Regards
Balkrishan
Re: FFT of an image
In matlab? How about fft2() function.
To actually implement this in an FPGA, you'll want to do something like has been suggested by FFT-ing in the horizontal and then in the vertical.
www.xilinx.com
Re: FFT of an image
Thanks bwic,
So does that mean 1d FFT is only for Signal processing and 2D fft for image??
also what exactly is the output of 1D and 2D FFT shows ??
I mean what we see ,a frequency spectrum or anything else??
Re: FFT of an image
Recently I want to realize convolution of two images. I am a newbie,it has taken me about 2 mouths .I dont't know where is wrong.First I want realise fft of an image .Any one can give some suggestion ?
My fft configuration :
transform length:512 Target clock frequency:250Mhz Phase factor width:16
Unscaled Convergent rounding Natural order Number of stages using Block RAM:4
the image is 256*256
Re: FFT of an image
Sorry to bother you .I am wondering when i was implementing the fft of an image,can I use the FFT xilinx ip core.And how to do with it ?
Re: FFT of an image
Hi @xiaomayiyaojianqiango
Our Community Help has a tip that might help you : Tip: If the message is older than 6-12 months, please post a new message rather than adding to the existing thread. Your inquiry will have a better chance of being picked up by an expert if it is a new topic.
https://forums.xilinx.com/t5/help/faqpage/faq-category-id/posting#posting
I would suggest you create a new topic on the appropriate board
Florent
