shaikon
Voyager
Voyager
FIR Compiler - inconsistencies between documentation and IP
From reading this document :
https://www.xilinx.com/support/documentation/ip_documentation/fir_compiler/v7_2/pg149-fir-compiler.pdf
I learn that the FIR compiler supports more the one filter architectures.
However, when I look inside the core I find only "Systolic Multiply Accumulate".
Why is that ?
vkanchan
Hi @shaikon ,
PG149 states that Systolic MAC architecture exploits Filter symmetry while the Transpose MAC architecture does not. If the "coefficient structure" option  in "Implementation Tab" is set to symmetric or if inferred as symmetric, then only Systolic MAC architecture is present.
If the coefficient structure is set to Non-symmetric or inferred as Non-symmetric, then Transpose MAC architecture is also available.
vkanchan
Hi @shaikon ,
