FIR Compiler problem: Output channels getting swapped
I am facing this peculiar problem with the FIR compiler v 5.0 (ISE 11.2, Virtex SXT95). I am implementing a 6-channel decimation-by-5 FIR filter using this core. The outputsare get decimated as expected. However, in every cycle, the outputs get swapped in the sequence and appear on different channels (in the functional simulation in ModelSim XE 6.4b). I rely on chan_out signal to separate the outputs and the sequence is different in every cycle.
While debugging this design, I performed the following checks:
- I checked my input stream to see if the channels get swapped at the input stage itself. But they don't.
- I checked if the nd signal is any way different in the other cycles. It is same.
Has anyone encountered the similar problem?
Kumar Vijay Mishra.
I resolved the problem of outputs getting clipped. Turns out I was using SCLR (deterministic behavior) option for the FIR core. When this happens, the core forces output to be zero initially till it flushes out the internal values. Some portion of my valid input was in this time period and hence its corresponding output was forced to zero. I delayed my input and could then see the full output.
Kumar Vijay Mishra.
Turns out I was not properly resetting the core in every cycle. After fixing this bug, the channels are in the expected order. However, the initial part of the channels gets clipped. Any clue? Should I pad the inputs with zeros in the beginning?
Kumar Vijay Mishra.
Kumar Vijay Mishra.
