Hago231
FIR Compiler s_axi_tdata_tready
Hi all,
I'm having a difficult time trying to figure out what I'm doing wrong here:
I've created an FIR Compiler v7.2 ip with reloadable coefficients. the coeffs width is 2 bits, and there is only one set and one channel.
The problem is, no matter what I do, the s_axi_tdata_tready does not change from its initial state of 'U'. I'm reloading the coeffs using the RELOAD port; upon done reloading, I'm waiting long enough until the CONFIG tvalid is triggered. Why is the s_axi_tdata_tready not changing?
I was not sure what the s_axis_config_tdata signal should contain, since I have 1 channel and 1 coeffs set (it is 8 bits wide) - so I set it all 1s, all 0s, 01, 10 etc. Didn't matter.
Hago
vkanchan
Hi @Hago231 ,
Did you try simulating the FIR IP with its example test bench ? If not, could you check if the IP shows the same behavior with the example test bench ?
