Visitor robroy
Failed to read or parse strategy file SysGen 2018.1
I'm using the following system:
OS: CentOS Linux release 7.6.1810
MATLAB version: 2018a (tried using 2017b but encountered the error described in the following post and followed their fix to upgrade to 2018a, 2017b and 2018.1 incomp.)
Vivado version: 2018.1
I'm trying to test SysGen out but I'm encountering issues when placing basic building blocks. I'm recieving the following warning when placing a System Generator token as the first object in my design:
Warning: Failed to read or parse strategy file /opt/Xilinx/Vivado/2018.1/bin/strategies/VDS2017.psg
> In xilinx.environment/getStrategyAttrsFromFile
In xilinx.environment.loadAllStrategies
Warning: Error evaluating 'PreLoadFcn' callback of block_diagram 'xbsBasic_r4'.
Callback string is 'warning('off','MATLAB:mex:deprecatedExtension');xlSysGenPreLoadCheck;xlmeta;evalin('base','xilinx.environment.loadAllStrategies();');'
Warning: Output argument "strats" (and maybe others) not assigned during call to "xilinx.environment/getStrategyAttrsFromFile".
Warning: Error evaluating 'PreLoadFcn' callback of block_diagram 'xbsIndex_r4'.
Warning: Error evaluating 'CopyFcn' callback of Xilinx System Generator Block block (mask) 'untitled/ System Generator'.
Callback string is 'xlBlockMoveCallback(gcbh);xlSysgenGUI('copy',gcbh);'
Warning: Unexpected Standard exception from MEX file.
What() is:Failed to open file for read: /opt/Xilinx/Vivado/2018.1/bin/data/sysgen/blockstatus/VivadoIPLifeCycleSchedule.txt
In xlSysgenGUI
If I try to place something else in the same diagram afterwards I get the following message:
Warning: Error evaluating 'CopyFcn' callback of Xilinx Gateway In Block block (mask) 'untitled/Gateway In'.
Callback string is 'xlBlockMoveCallback(gcbh);'
If I try to double click on the System Generator token as to edit it's settings I get the following error in an pop-up box:
Error evaluating 'OpenFcn' callback of Xilinx System Generator Block block (mask) 'untitled/ System Generator'. Callback string is 'xlSysgenGUI('startup',gcs,gcbh);'
and the following get's printed in the command window:
In xlSysgenGUI
Any help would be much appreciated!
Visitor robroy
Re: Failed to read or parse strategy file SysGen 2018.1
Solution found in that I had earlier edited my startup.m file to append a file path for Mathworks HDL Coder, by the following command: hdlsetuptoolpath('ToolName', 'Xilinx Vivado', 'ToolPath', '/opt/Xilinx/Vivado/2018.1/bin/');
Removing that line from the startup.m file fixed this issue for some strange reason, I suppose it either overwrites something used by SysGen or it runs before something else and thus blocking SysGen's possibility to call on that something.
Visitor robroy
